consider that i have to display an i frame 10 times, so instead of sending the I frame 10 times, is it possible to send the i frame once in the beginning following which will be p frames 9 times (by converting i frame to p frame). I won't to do this to decrease the size.
AFAIK, a p frame refers to the earlier frame (i or p) .A p frame contains the motion vectors for macroblocks in the preceding frame and also new intracoded macroblocks that weren't there in the preceding frame. But in my case the latter part won't be there as same frame is sent again. so i suppose the motion vectors will never change, their value will remain zero as nothings moving.
plz, i need some guidance to achieve this ASAP. any MPEG expert out there? i deal with MPEG2.
Results 1 to 1 of 1
Frame-By-Frame Restored James Bond Films Released
By Soopafresh in forum RestorationReplies: 9Last Post: 27th Apr 2012, 14:09 -
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
WMP and VB6, is it possible to step forward or back frame by frame?
By gadgetguy in forum ProgrammingReplies: 11Last Post: 6th Mar 2009, 20:00 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 22:53
