This is the first time I try burning a DVD-R. I need help please. I converted my AVI files using WinAVi. After that they became VOB files and I'm able to play them with PowerDVD (PC's DVD player). I can't figure out how to burn the VOB files using DiscJuggler. I have Sony DVD-ROM and Sony CD-RW, every time I try to load them it tells me its unable to burn. Please help me if you can. Thanks.
You do need a DVD writer...
/Mats -
If you have the complete VIDEO_TS folder and it contains DVD compliant video and audio, you just need to burn it. The freeware ImgBurn works well for that. For the DVD specification and format see 'WHAT IS' DVD to the upper left. <<<<<<
Burning a VIDEO_TS folder with ImgBurn: http://forum.imgburn.com/index.php?showforum=4
I'm assuming you have a DVD-RW besides a DVD-ROM as a ROM is just a reader.
If you need a DVD burner you can buy one for around $50 or less even sometimes. For instance BEST BUY carries the Pioneer DVR-710 which is a good model but they do charge $69.99 for it.
You can get a better price if you shop on-line at a place like NEWEGG.COM
For instance at NEWEGG.COM you can get the Pioneer DVR-111D for $31.99 + shipping.
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 04:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
