2nd HD Western Digital 160G as Slave (Storage, etc only), OS on Primary HD and works fine.
On this 2nd HD, some files like MP3s, DVD movies (VOBs) were UNABLE to retrieve even windows show sizes on each files. Randomly does this to my files time to time. It is like the files are corrupted, viruses, bugs, or something? Defrag no help...any suggestions?
Thanks in advance.
Have you ran error checking on it from the drives property page? And if your motherboard has S.M.A.R.T capability, I would turn it on in BIOS. If the problem is only on that drive, maybe the drive is failing? S.M.A.R.T will usually give you some warning before it fails.
Am I understanding correctly that the main problem is that the file sizes are shown incorrectly or are the files themselves apparently corrupted?
The only other thing I can think of is to move the data off it and reformat and see if that cleans it up. It could be a virus or some sort of malware, but that would usually effect the boot drive more often. -
Dont overclock...its easy to cause data degradation if you are ocking the FSB. maybe "scan" the disk from dos or error check from windows
The electronic components of the power part adopted a lot of Rubycons.
Capturing from one PC to a 2nd one
By Smoerble in forum Capturing and VCRReplies: 1Last Post: 18th Jan 2012, 11:22 -
XP not seeing format of 2nd HDD
By j1d10t in forum ComputerReplies: 9Last Post: 21st Feb 2011, 15:30 -
Adding a 2nd Monitor
By Tafflad in forum ComputerReplies: 3Last Post: 4th Feb 2010, 11:11 -
2nd Angle plus subs?
By Jeikobu in forum MacReplies: 2Last Post: 18th Jul 2008, 09:25 -
Help installing 2nd HDD
By Rudyard in forum ComputerReplies: 8Last Post: 21st Feb 2008, 00:59
