Please someone help me. I have had really bad problems with my laptop Pioneer burner DVR-K14RA being unable to burn DVD's. It's a relatively recent development, but i've tried changing media both types tried are class 1 discs, i.e Sony (D11), and Verbatim (MCC 004). I've never had a problem with the Sony discs, but then it started turning them into coasters. I've only managed to burn 1 Verbatim disc, the first one I used. The drive burns CD's fine. I use DVD+R media as this seems to be the most compatible with my LG 4750 standalone player.
I'm trying to burn Lost S3 (4 per disc), and Weeds S2 (6 per disc) for friends. They are in DivX format. I've tried using the following programs to convert/burn the programs. I've tried burning straight to disc and also by trying to burn an image, to burn to disc.
VSO DivXtoDVD
Nero Vision 4
NTI CD/DVD maker
Power Producer Gold
ImgBurn
They seem to work be burning fine, and then at the last minute are unable to write the TOC.
I've saved the Nero failure log. Can someone shed some light on the situation. Here's the log. It doesn't mean much to me:
Rob's Space
1C82-0000-19E5-MAAX-4001-5180-****
1C83-7617-10E5-477X-4022-6KM9-****
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 13:54:32
NT-SPTI used
Nero Version: 7.5.7.0
Internal Version: 7, 5, 7, 0
Recorder: <PIONEER DVD-RW DVR-K14RA>Version: 1.00 - HA 1 TA 0 - 7.5.7.0
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <NERO IMAGEDRIVE2 >Version: 2.26 - HA 1 TA 1 - 7.5.7.0
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : ST960821A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-K14RA atapi Port 1 ID 0 DMA: On
CdRomPeripheral : NERO IMAGEDRIVE2 2.26 imagedrv Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-K14RA E: CDRom0
NERO IMAGEDRIVE2 F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
BUFE : 0
Physical memory : 510MB (523244kB)
Free physical memory: 106MB (108904kB)
Memory in use : 79 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.11.2006
Burn DVD Image
08:16:02 #1 Text 0 File SCSIPassThrough.cpp, Line 583
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
08:16:02 #2 IMAGEGEN -10 File ImageGen.cpp, Line 366
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x00
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 4656365568
CUES:
MTYP: Mediumtype = DVD (old format) (0x1C)
Image file name: <C:\dvd images\weeds disc1.nrg>
08:16:02 #3 Text 0 File Burncd.cpp, Line 3435
Turn on Disc-At-Once, using DVD media
08:16:02 #4 Text 0 File DlgWaitCD.cpp, Line 301
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2273615 (505:14.65, 4440MB)
08:16:02 #5 Text 0 File DlgWaitCD.cpp, Line 313
Write in overburning mode: NO (enabled: CD)
08:16:02 #6 Text 0 File DlgWaitCD.cpp, Line 2863
Recorder: PIONEER DVD-RW DVR-K14RA, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
08:16:02 #7 Text 0 File DlgWaitCD.cpp, Line 485
>>> Protocol of DlgWaitCD activities: <<<
08:16:02 #8 Text 0 File ThreadedTransferInterface.cpp, Line 820
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - DVD-ROM)
2 indices, index0 (150) not provided
original disc pos #0 + 2273616 (2273616) = #2273616/505:14.66
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2273616 blocks [Main]
08:16:02 #9 Text 0 File ThreadedTransferInterface.cpp, Line 1033
Prepare recorder [PIONEER DVD-RW DVR-K14RA] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4656365568, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 2273616 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2273616 | 0 | 0x00
2273616 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
08:16:02 #10 Text 0 File SCSIPassThrough.cpp, Line 41
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
08:16:02 #11 Phase 24 File dlgbrnst.cpp, Line 1746
Caching of files started
08:16:02 #12 Text 0 File Burncd.cpp, Line 4262
Cache writing successful.
08:16:02 #13 Phase 25 File dlgbrnst.cpp, Line 1746
Caching of files completed
08:16:02 #14 Phase 28 File dlgbrnst.cpp, Line 1746
Speed measurement started
08:16:02 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2730
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
08:18:49 #16 Text 0 File WriterStatus.cpp, Line 112
<PIONEER DVD-RW DVR-K14RA> start writing Lead-Out at LBA 2273616 (22B150h), length 0 blocks
08:18:49 #17 Phase 29 File dlgbrnst.cpp, Line 1695
Speed measurement completed: 20.1x (27,740 KB/s)
08:18:49 #18 Phase 36 File dlgbrnst.cpp, Line 1746
Burn process started at 4x (5,540 KB/s)
08:18:49 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2730
08:18:49 #20 Text 0 File Cdrdrv.cpp, Line 9234
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: MCC.....
Media type ID: 004
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8
23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08 #T7..Tl.._......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
08:18:49 #21 SPTI -1066 File SCSIPassThrough.cpp, Line 293
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x06ba8200: Len x648
08:18:49 #22 Text 0 File DVDPlusRW.cpp, Line 662
Start write address at LBA 0
DVD high compatibility mode: Yes
08:18:52 #23 Text 0 File Cdrdrv.cpp, Line 1290
08:18:52.234 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #24 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.765 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #25 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.796 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #26 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09 #27 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.812 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #28 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.828 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #29 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.859 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #30 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.875 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #31 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.890 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #32 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.906 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #33 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.937 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #34 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.953 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #35 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.968 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #36 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.984 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #37 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.000 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #38 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.031 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #39 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.046 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #40 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.140 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #41 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10 #42 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.156 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #43 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.171 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #44 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.203 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #45 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.218 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #46 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.234 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #47 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.250 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #48 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.265 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #49 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.296 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #50 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.312 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #51 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.328 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #52 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.343 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #53 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.390 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #54 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.406 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #55 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.437 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #56 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.453 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #57 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.468 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #58 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.484 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #59 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.500 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #60 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.531 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #61 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.546 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #62 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.562 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #63 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.578 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #64 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.609 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #65 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.625 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #66 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.640 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #67 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.656 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #68 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.718 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #69 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.734 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #70 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.750 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #71 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.765 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #72 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.796 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #73 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.812 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #74 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.828 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #75 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.843 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #76 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.875 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #77 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10 #78 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.906 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #79 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.921 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #80 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.953 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #81 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.015 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #82 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.046 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #83 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.062 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #84 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.078 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #85 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.093 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #86 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.109 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #87 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.140 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #88 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.156 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #89 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.171 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #90 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.187 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #91 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.218 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #92 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.234 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #93 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.250 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #94 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.296 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #95 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.312 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #96 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11 #97 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.343 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #98 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.359 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #99 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.390 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #100 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11 #101 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.421 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #102 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.437 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #103 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.453 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #104 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.484 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #105 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11 #106 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.515 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #107 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.531 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #108 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.593 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #109 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.625 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #110 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.640 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #111 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.671 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #112 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.687 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #113 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.703 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #114 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.718 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #115 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.750 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #116 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.765 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #117 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.781 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #118 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.796 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #119 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.812 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #120 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.843 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #121 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.906 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #122 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.937 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:33:44 #123 Text 0 File WriterStatus.cpp, Line 112
08:34:03 #124 CDR -1122 File ThreadedTransferInterface.cpp, Line 1921
Unable to recover TOC
08:34:03 #125 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1921
Could not perform end of Disc-at-once
08:34:04 #126 SPTI -1122 File SCSIPassThrough.cpp, Line 293
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1122)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x57
Sense Qual: 0x00
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0E 00 00 00 00 57
Buffer x04f09e00: Len x20
08:34:04 #127 SPTI -1122 File SCSIPassThrough.cpp, Line 293
Sense Code: 0x57
Sense Qual: 0x00
CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
08:34:04 #128 Phase 127 File dlgbrnst.cpp, Line 1746
Generating DVD high compatibility borders
08:34:04 #129 CDR -1122 File WriterStatus.cpp, Line 161
08:34:04 #130 TRANSFER -24 File WriterStatus.cpp, Line 161
08:34:04 #131 Phase 38 File dlgbrnst.cpp, Line 1746
Burn process failed at 4x (5,540 KB/s)
08:34:04 #132 Text 0 File Cdrdrv.cpp, Line 10459
DriveLocker: UnLockVolume completed
08:34:04 #133 Text 0 File SCSIPassThrough.cpp, Line 583
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 25/04/2005 09:03:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 04/08/2004 05:00:00 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 1 of 1
Can't use ISOBuster to recover from coaster
By dare2be in forum MediaReplies: 8Last Post: 29th Mar 2011, 07:07 -
Burner can only burn to Verbatim Media, but not anymore...
By iownju in forum MediaReplies: 6Last Post: 19th May 2010, 06:53 -
Any way to write anything to a coaster?
By lbeck in forum MediaReplies: 12Last Post: 29th Apr 2010, 18:28 -
Debugging coaster problem
By txporter in forum MediaReplies: 21Last Post: 29th Apr 2009, 06:43 -
Nero 9.2.5.0 - Can't burn anymore (error message enclosed)
By rock_king_my in forum Newbie / General discussionsReplies: 9Last Post: 14th Apr 2009, 11:02
