Please someone help me. I have had really bad problems with my laptop Pioneer burner DVR-K14RA being unable to burn DVD's. It's a relatively recent development, but i've tried changing media both types tried are class 1 discs, i.e Sony (D11), and Verbatim (MCC 004). I've never had a problem with the Sony discs, but then it started turning them into coasters. I've only managed to burn 1 Verbatim disc, the first one I used. The drive burns CD's fine. I use DVD+R media as this seems to be the most compatible with my LG 4750 standalone player.
I'm trying to burn Lost S3 (4 per disc), and Weeds S2 (6 per disc) for friends. They are in DivX format. I've tried using the following programs to convert/burn the programs. I've tried burning straight to disc and also by trying to burn an image, to burn to disc.
VSO DivXtoDVD
Nero Vision 4
NTI CD/DVD maker
Power Producer Gold
ImgBurn
They seem to work be burning fine, and then at the last minute are unable to write the TOC.
I've saved the Nero failure log. Can someone shed some light on the situation. Here's the log. It doesn't mean much to me:
Rob's Space
1C82-0000-19E5-MAAX-4001-5180-****
1C83-7617-10E5-477X-4022-6KM9-****
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 13:54:32
NT-SPTI used
Nero Version: 7.5.7.0
Internal Version: 7, 5, 7, 0
Recorder: <PIONEER DVD-RW DVR-K14RA>Version: 1.00 - HA 1 TA 0 - 7.5.7.0
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <NERO IMAGEDRIVE2 >Version: 2.26 - HA 1 TA 1 - 7.5.7.0
Adapter driver: <SCSI> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : ST960821A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-K14RA atapi Port 1 ID 0 DMA: On
CdRomPeripheral : NERO IMAGEDRIVE2 2.26 imagedrv Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-K14RA E: CDRom0
NERO IMAGEDRIVE2 F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
BUFE : 0
Physical memory : 510MB (523244kB)
Free physical memory: 106MB (108904kB)
Memory in use : 79 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.11.2006
Burn DVD Image
08:16:02 #1 Text 0 File SCSIPassThrough.cpp, Line 583
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
08:16:02 #2 IMAGEGEN -10 File ImageGen.cpp, Line 366
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x00
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = 4656365568
CUES:
MTYP: Mediumtype = DVD (old format) (0x1C)
Image file name: <C:\dvd images\weeds disc1.nrg>
08:16:02 #3 Text 0 File Burncd.cpp, Line 3435
Turn on Disc-At-Once, using DVD media
08:16:02 #4 Text 0 File DlgWaitCD.cpp, Line 301
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2273615 (505:14.65, 4440MB)
08:16:02 #5 Text 0 File DlgWaitCD.cpp, Line 313
Write in overburning mode: NO (enabled: CD)
08:16:02 #6 Text 0 File DlgWaitCD.cpp, Line 2863
Recorder: PIONEER DVD-RW DVR-K14RA, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
08:16:02 #7 Text 0 File DlgWaitCD.cpp, Line 485
>>> Protocol of DlgWaitCD activities: <<<
08:16:02 #8 Text 0 File ThreadedTransferInterface.cpp, Line 820
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - DVD-ROM)
2 indices, index0 (150) not provided
original disc pos #0 + 2273616 (2273616) = #2273616/505:14.66
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2273616 blocks [Main]
08:16:02 #9 Text 0 File ThreadedTransferInterface.cpp, Line 1033
Prepare recorder [PIONEER DVD-RW DVR-K14RA] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4656365568, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 2273616 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2273616 | 0 | 0x00
2273616 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
08:16:02 #10 Text 0 File SCSIPassThrough.cpp, Line 41
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
08:16:02 #11 Phase 24 File dlgbrnst.cpp, Line 1746
Caching of files started
08:16:02 #12 Text 0 File Burncd.cpp, Line 4262
Cache writing successful.
08:16:02 #13 Phase 25 File dlgbrnst.cpp, Line 1746
Caching of files completed
08:16:02 #14 Phase 28 File dlgbrnst.cpp, Line 1746
Speed measurement started
08:16:02 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2730
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
08:18:49 #16 Text 0 File WriterStatus.cpp, Line 112
<PIONEER DVD-RW DVR-K14RA> start writing Lead-Out at LBA 2273616 (22B150h), length 0 blocks
08:18:49 #17 Phase 29 File dlgbrnst.cpp, Line 1695
Speed measurement completed: 20.1x (27,740 KB/s)
08:18:49 #18 Phase 36 File dlgbrnst.cpp, Line 1746
Burn process started at 4x (5,540 KB/s)
08:18:49 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2730
08:18:49 #20 Text 0 File Cdrdrv.cpp, Line 9234
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: MCC.....
Media type ID: 004
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8
23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08 #T7..Tl.._......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
08:18:49 #21 SPTI -1066 File SCSIPassThrough.cpp, Line 293
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x06ba8200: Len x648
08:18:49 #22 Text 0 File DVDPlusRW.cpp, Line 662
Start write address at LBA 0
DVD high compatibility mode: Yes
08:18:52 #23 Text 0 File Cdrdrv.cpp, Line 1290
08:18:52.234 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #24 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.765 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #25 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.796 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #26 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09 #27 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.812 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #28 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.828 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #29 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.859 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #30 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.875 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #31 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.890 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #32 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.906 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #33 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.937 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #34 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.953 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #35 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.968 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:09 #36 Text 0 File Cdrdrv.cpp, Line 1290
08:19:09.984 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #37 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.000 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #38 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.031 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #39 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.046 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #40 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.140 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #41 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10 #42 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.156 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #43 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.171 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #44 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.203 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #45 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.218 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #46 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.234 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #47 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.250 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #48 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.265 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #49 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.296 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #50 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.312 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #51 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.328 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #52 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.343 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #53 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.390 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #54 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.406 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #55 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.437 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #56 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.453 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #57 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.468 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #58 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.484 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #59 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.500 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #60 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.531 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #61 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.546 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #62 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.562 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #63 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.578 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #64 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.609 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #65 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.625 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #66 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.640 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #67 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.656 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #68 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.718 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #69 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.734 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #70 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.750 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #71 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.765 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #72 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.796 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #73 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.812 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #74 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.828 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #75 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.843 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #76 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.875 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #77 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10 #78 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.906 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #79 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.921 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:10 #80 Text 0 File Cdrdrv.cpp, Line 1290
08:19:10.953 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #81 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.015 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #82 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.046 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #83 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.062 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #84 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.078 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #85 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.093 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #86 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.109 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #87 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.140 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #88 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.156 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #89 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.171 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #90 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.187 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #91 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.218 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #92 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.234 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #93 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.250 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #94 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.296 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #95 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.312 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #96 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11 #97 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.343 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #98 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.359 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #99 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.390 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #100 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11 #101 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.421 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #102 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.437 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #103 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.453 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #104 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.484 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #105 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11 #106 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.515 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #107 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.531 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #108 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.593 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #109 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.625 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #110 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.640 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #111 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.671 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #112 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.687 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #113 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.703 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #114 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.718 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #115 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.750 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #116 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.765 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #117 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.781 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #118 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.796 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #119 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.812 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #120 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.843 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #121 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.906 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:19:11 #122 Text 0 File Cdrdrv.cpp, Line 1290
08:19:11.937 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
08:33:44 #123 Text 0 File WriterStatus.cpp, Line 112
08:34:03 #124 CDR -1122 File ThreadedTransferInterface.cpp, Line 1921
Unable to recover TOC
08:34:03 #125 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1921
Could not perform end of Disc-at-once
08:34:04 #126 SPTI -1122 File SCSIPassThrough.cpp, Line 293
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1122)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x57
Sense Qual: 0x00
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0E 00 00 00 00 57
Buffer x04f09e00: Len x20
08:34:04 #127 SPTI -1122 File SCSIPassThrough.cpp, Line 293
Sense Code: 0x57
Sense Qual: 0x00
CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
08:34:04 #128 Phase 127 File dlgbrnst.cpp, Line 1746
Generating DVD high compatibility borders
08:34:04 #129 CDR -1122 File WriterStatus.cpp, Line 161
08:34:04 #130 TRANSFER -24 File WriterStatus.cpp, Line 161
08:34:04 #131 Phase 38 File dlgbrnst.cpp, Line 1746
Burn process failed at 4x (5,540 KB/s)
08:34:04 #132 Text 0 File Cdrdrv.cpp, Line 10459
DriveLocker: UnLockVolume completed
08:34:04 #133 Text 0 File SCSIPassThrough.cpp, Line 583
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 25/04/2005 09:03:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\scsiport.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 04/08/2004 05:00:00 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 24 of 24
looks like burner is dead ......
also - please see rules - re: warez (downloaded tv shows) ...... thanks"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
You need to replace the DVD burner. Pioneer drive/burner laser does not last very well.
Originally Posted by greymalkin
Thanks, I needed a laugh.
Burn Weasel,
You need a new burner.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Well, did you install/change anything prior to the problem. I have once experience something similar and I thought the drive is dead. Buy a new one and it plays OK. Put the old drive in another computer and it run OK. Seems like problem with driver (conflict?).
Before you buy a new drive, you might try cleaning this one.
Thanks for your theories, but:
a) How can the burner be dead if it can still burn CD's O.k?!
b) Also, i'm not burning anything that has DRM or any kind of protection. It is all legitmiately downloaded DivX from US series that have aired on TV in the public domain in the States.
c) I don't believe I have changed anything in my hardware (it's a laptop), or my software, though I run Norton Internet Security. Maybe I should have a go with it disabled?! I also do tend to update i-tunes to the latest version when it prompts me to, auto-run windows update regularly. In addition, if I uninstall some DVD software and leave others, i.e NTI CD/DVD maker, PowerProducer, will they delete files required by the programs left behind that use the burner? -
There are two lasers.Originally Posted by Burn Weasel
It is considered warez, because you did not buy the dvd's. The shows are available on dvd.b) Also, i'm not burning anything that has DRM or any kind of protection. It is all legitmiately downloaded DivX from US series that have aired on TV in the public domain in the States.
had the same problem with my NEC 1300. used it for years, ripped/burned 1000's of CDs and DVDs. one day all aspects of it worked with the exception of burning DVDRs.
replaced the drive with NEC 3540. best $36 ever invested in my computering history.
BTW the 3540 is following the 1300's footsteps RE: reliability. it's just a lot faster!! -
Try burning a simple data DVD and test that. Burning a CD does not use the same components of the drive that burning a DVD does.
Burning a data DVD tests simple functionality and eliminates the complicating factor of the video conversion.
Cleaning also a good idea, very inexpensive and no risk if you are going to replace the drive, anyway. -
They used to advertised about twin lasers in the CD/DVD drive/burner. Two lasers are needed because CD and DVD uses different wavelength of laser light, to do thy bidding.
It becomes a norm that drive and burner have to support both CD and DVD. So they all comes with twin lasers. The laser that get use the most, will failed first.
Those new BD/DVD/CD burners much have three lasers. -
1) If it was legitimate you'd better believe it would have some type of protection to try and keep you from sharing with your friends.Originally Posted by Burn Weasel
2) Using your logic I can download any movie I want as long as it was shown on TV somewhere at some time. You can't make up your own laws. -
Hi
Here's an update. I've tried burning a data DVD with the same files and it works fine. Burnt and verified. No problem whatsoever.
So could there be some codec issue? I'm using the latest version of FFDShow. Also have the Patin-Couffin engine installed as part of VSO's software, could there be a conflict?
Also, I don't want to get into a 'piracy' slanging match, let's just focus on the hardware issue please. Cheers. -
Oh....crap, here's another update. I just tried burning another data disc and this time got the same error as before with not being able to create the TOC. Here's the error log, i noticed that the 'sense key' is 'illegal'. What the hell does that mean??:
Rob's Space
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Free physical memory: 101MB (103868kB)
Memory in use : 80 %
Use Inquiry : 1
15.11.2006
ISO compilation
18:05:26 #1 Text 0 File SCSIPassThrough.cpp, Line 583
18:05:27 #2 Text 0 File Isodoc.cpp, Line 6508
Iso document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
18:05:27 #3 ISO9660GEN -11 File Geniso.cpp, Line 3313
First writeable address = 0 (0x00000000)
18:05:27 #4 Text 0 File Burncd.cpp, Line 3435
18:05:27 #5 Text 0 File DlgWaitCD.cpp, Line 301
Last address to be written: 1423087 (316:14.37, 2779MB)
18:05:27 #6 Text 0 File DlgWaitCD.cpp, Line 313
18:05:27 #7 Text 0 File DlgWaitCD.cpp, Line 2863
18:05:27 #8 Text 0 File DlgWaitCD.cpp, Line 485
18:05:27 #9 Text 0 File ThreadedTransferInterface.cpp, Line 820
0: TRM_DATA_MODE1 ()
original disc pos #0 + 1423088 (1423088) = #1423088/316:14.38
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1423088 blocks [Main]
18:05:27 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1033
DAO infos:
MCN: ""
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2914484224, ISRC ""
DAO layout:
0 | 1 | 0 | 0x41 | 1423088 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1423088 | 0 | 0x00
1423088 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
18:05:27 #11 Text 0 File SCSIPassThrough.cpp, Line 41
18:05:27 #12 Phase 24 File dlgbrnst.cpp, Line 1746
18:05:27 #13 Text 0 File Burncd.cpp, Line 4262
18:05:27 #14 Phase 25 File dlgbrnst.cpp, Line 1746
18:05:27 #15 Phase 28 File dlgbrnst.cpp, Line 1746
18:05:27 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2730
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:08:51 #17 Text 0 File WriterStatus.cpp, Line 112
<PIONEER DVD-RW DVR-K14RA> start writing Lead-Out at LBA 1423088 (15B6F0h), length 0 blocks
18:08:51 #18 Phase 29 File dlgbrnst.cpp, Line 1695
Speed measurement completed: 10.3x (14,244 KB/s)
18:08:51 #19 Phase 36 File dlgbrnst.cpp, Line 1746
18:08:51 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2730
18:08:51 #21 Text 0 File Cdrdrv.cpp, Line 9234
Media type ID: 004
18:08:51 #22 SPTI -1066 File SCSIPassThrough.cpp, Line 293
Sense Code: 0x24
Sense Qual: 0x00
Buffer x06a55600: Len x648
18:08:51 #23 Text 0 File DVDPlusRW.cpp, Line 662
18:08:55 #24 Text 0 File Cdrdrv.cpp, Line 1290
18:08:55.453 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #25 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.015 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #26 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.046 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #27 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13 #28 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.062 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #29 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.093 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #30 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.109 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #31 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.125 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #32 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.140 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #33 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.156 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #34 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.187 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #35 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.203 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #36 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.218 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #37 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.234 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #38 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.265 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #39 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.281 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #40 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.375 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #41 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.406 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #42 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13 #43 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.437 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #44 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.453 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #45 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.468 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #46 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.484 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #47 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.500 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #48 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.531 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #49 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.546 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #50 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.562 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #51 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.578 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #52 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.625 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #53 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.640 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #54 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.656 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #55 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.671 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #56 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.703 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #57 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.718 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #58 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.750 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #59 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13 #60 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.765 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #61 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.796 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #62 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.812 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #63 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.828 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #64 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.843 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #65 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.875 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #66 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.890 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #67 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.937 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #68 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.968 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:13 #69 Text 0 File Cdrdrv.cpp, Line 1290
18:09:13.984 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #70 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.015 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #71 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14 #72 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.031 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #73 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.062 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #74 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.078 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #75 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.109 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #76 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14 #77 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.140 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #78 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.156 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #79 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.171 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #80 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.265 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #81 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.281 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #82 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.296 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #83 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14 #84 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.328 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #85 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.343 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #86 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.375 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #87 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14 #88 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.406 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #89 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.421 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #90 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.453 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #91 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14 #92 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.484 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #93 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.546 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #94 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14 #95 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.578 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #96 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.593 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #97 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.625 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #98 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.640 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #99 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14 #100 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.671 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #101 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.687 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #102 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.718 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #103 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14 #104 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.750 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #105 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.765 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #106 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.828 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #107 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.859 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #108 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.875 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #109 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.906 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #110 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.921 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #111 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.937 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #112 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.953 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:14 #113 Text 0 File Cdrdrv.cpp, Line 1290
18:09:14.984 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:15 #114 Text 0 File Cdrdrv.cpp, Line 1290
18:09:15.000 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:15 #115 Text 0 File Cdrdrv.cpp, Line 1290
18:09:15.015 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:15 #116 Text 0 File Cdrdrv.cpp, Line 1290
18:09:15.031 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:15 #117 Text 0 File Cdrdrv.cpp, Line 1290
18:09:15.046 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:15 #118 Text 0 File Cdrdrv.cpp, Line 1290
18:09:15.062 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:15 #119 Text 0 File Cdrdrv.cpp, Line 1290
18:09:15.156 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:15 #120 Text 0 File Cdrdrv.cpp, Line 1290
18:09:15 #121 Text 0 File Cdrdrv.cpp, Line 1290
18:09:15.187 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:15 #122 Text 0 File Cdrdrv.cpp, Line 1290
18:09:15.203 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:09:15 #123 Text 0 File Cdrdrv.cpp, Line 1290
18:09:15.218 - E: PIONEER DVD-RW DVR-K14RA : Queue again later
18:18:31 #124 Text 0 File WriterStatus.cpp, Line 112
18:18:50 #125 CDR -1122 File ThreadedTransferInterface.cpp, Line 1921
18:18:50 #126 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1921
18:18:50 #127 SPTI -1122 File SCSIPassThrough.cpp, Line 293
Sense Code: 0x57
Sense Qual: 0x00
18:18:50 #128 SPTI -1122 File SCSIPassThrough.cpp, Line 293
Sense Code: 0x57
Sense Qual: 0x00
18:18:50 #129 Phase 127 File dlgbrnst.cpp, Line 1746
18:18:50 #130 CDR -1122 File WriterStatus.cpp, Line 161
18:18:50 #131 TRANSFER -24 File WriterStatus.cpp, Line 161
18:18:50 #132 Phase 38 File dlgbrnst.cpp, Line 1746
18:18:50 #133 Text 0 File Cdrdrv.cpp, Line 10459
18:18:50 #134 Text 0 File SCSIPassThrough.cpp, Line 583
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) -
Possible causes - bad discs, or bad drive
You should be ashamed of yourself for asking for help with warez.Believing yourself to be secure only takes one cracker to dispel your belief. -
yes we're really obligated to tell you that we don't approve of this here at videohelp. If we didn't then every 14 year old wanting to back up his playstation games would be on here and the site would be shut down in no time for advocating warez.
I believe it was already determined that your dvd burner is gone anyways. Maybe your friends will pitch in and buy you a new one after all the money you saved them burning pirated dvd's. -
WTF,
Bunch of hippocrites. This site is littered with hints/links to software that enables you to strip DVD's to copy, and ahem 'back up' discs. I'm not doing that!
How can I be stealing something that has already been aired on TV that you or I or anyone could record on to Tivo, VHS, or DVD at home legitimately and lend to a friend. I'm a fan of shows like Lost and Weeds. I'm in the U.K, and I can't wait the month or so for it to make it's way onto our TV stations. (These shows aren't on Pay per view channels over here, so it's free anyway I might add)
I'm not hiring a DVD or buying one from a shop and then de-crypting it, stripping it of Macrovision, etc. and then burning it and selling it. How is that stealing?
Haven't you ever recorded something from the TV to watch and view with your friends?
These are shows recorded off TV. The laws maybe different in the US, I don't know, but over here it's fair game to use a piece of equipment like a VCR to record your favourite show and watch it.
I'm not advocating piracy, promoting it or whatever you seem to think...You lot seem far too paranoid. Afraid of the site getting shut down? -
We are copying discs that we own. That is the difference :POriginally Posted by Burn Weasel
Downloading divx rips of tv shows that you can buy on dvd is piracy.Originally Posted by Burn Weasel
.......wait for it.......You did not buy the discs.Originally Posted by Burn Weasel
Get a clue
Not strictly true. Lost Series 3 has yet to be aired on TV in the UK so you should not have access to it. In much the same way as the Region Coding system on DVDs was introduced to prevent a DVD that was released in the US as Region 1 could not, in theory, be seen by anyone in Europe (Region 2) before it was officially released there. Although not strictly Pay per View, the latest series of Lost has been bought by the robbing b*stards at Sky so is only available to Sky and Cable subscribers and consequently will not be available on any free to air service.Originally Posted by Burn Weasel
Yes, everyone throughout the world has recorded programmes from off air TV and watched them later, either alone or with a bunch of friends. When video recorders were first available there was considerable discussion over the legallity of being able to do this. It became generally accepted that to use a VCR to 'time shift' a programme was perfectly acceptable (even if technically illegal). To go any further was definitely not. Our laws are much the same as in the US. To record a TV programme that you are entitled to watch for viewing at a later time is perfectly legal. To then make copies and supply, whether free of charge or for payment, to upload it to the web or to supply to another in whatever format, is illegal. To download that illegally uploaded video is also illegal and to then burn it to DVD for onward supply to others is illegal. I suggest you make a few extra copies and try to sell them in your local pub or car boot sale and you will very quickly find out just how illegal it is (Summary offence carrying a Level 5 (up to 6 months custodial sentence and/or £5,000 fine) penalty).Originally Posted by Burn Weasel
However, ignoring for a moment what you are trying to burn, back to the original question. As has already been pointed out, your burner has 2 lasers of differing wavelengths. One for burning CDs and another for burning DVDs. Your DVD laser is dying, buy a new burner. -
Here is a simple answer on the legal question.
If I help you fix your car, no problem.
If you tell me you need the car fixed so you can run over your ex-wife, and I do it, I get to join you in prison. I may not be certain you are actually going to do the illegal act, but if there is any question whatsoever, the safe thing to do is not help you to perform the act.
As is stated in the FAQ, specific filenames are NOT necessary. They just cloud the issue with potential legal problems. We are not even supposed to discuss Macrovision anymore, this site has been contacted by lawyers from the opposition.
As to the writer, it seems to be toast. Cleaning the only thing you can realistically do. DVD burners are under $40.00 now. -
he mentioned it was for a laptop and dvd burners are not $40, maybe a desktop but i have yet to see one for a lappy, not like i'm really looking though.
you can use a external usb burner for a laptop - for under 70$
Burn Weasel,
The "KEY_ILLEGAL_REQUEST" error you saw in both logs you posted just means that the burning software sent a command to the drive that was malformed or "illegal". It was almost certainly caused by the drive not supporting a feature the software was trying to use. The software would then use another series of commands to accomplish the same task. The "KEY_ILLEGAL_REQUEST" error sounds much worse than it is, and it's very unlikely to be the cause of your problem.
The reason your drive is producing coasters is the "KEY_MEDIUM_ERROR" (atapi error code 035700) instances in the logs. After the burn was completed, the drive tries to read the table of contents (TOC) from the burned disk, but was unable to (in both logs). Since the drive thought it had successfully written it, but can't read it now, the source of the problem is either the drive or the media. The two logs only show the MCC004 being used, but it is good media and you say the Sony media didn't work either, so that just leaves the drive as the source of the problem.
You could replace the drive, but given that it's in a laptop, I'd like to second BJ_M's suggestion to get a external USB drive. It's a good solution to your current problem, and can be used on any future computer with a minimum of hassle.
Since your first post in this thread was your first post here, welcome to VideoHelp.
Can't use ISOBuster to recover from coaster
By dare2be in forum MediaReplies: 8Last Post: 29th Mar 2011, 07:07 -
Burner can only burn to Verbatim Media, but not anymore...
By iownju in forum MediaReplies: 6Last Post: 19th May 2010, 06:53 -
Any way to write anything to a coaster?
By lbeck in forum MediaReplies: 12Last Post: 29th Apr 2010, 18:28 -
Debugging coaster problem
By txporter in forum MediaReplies: 21Last Post: 29th Apr 2009, 06:43 -
Nero 9.2.5.0 - Can't burn anymore (error message enclosed)
By rock_king_my in forum Newbie / General discussionsReplies: 9Last Post: 14th Apr 2009, 11:02
