I have read and read. I need to remove the original audio from a video clip that is in WMV format using NERO. I want to add music to it.
If any one has any info on this I would great appreciate it.
Have a good one.
I have no idea how to do that with Nero, but a Google search for 'extract WMV audio' found this freeware program, among others that may work: http://www.freedownloadscenter.com/Best/free-wmv-audio.html Look for 'Free audio extractor' there.
If you extract it as a WAV, you can drop it into an audio editor like the freeware Audacity and modify it as wanted. From there, you will need to convert it back to a WMV format and figure out how to mux it back with the video. Windows Movie Maker might be a better tool for all this. WMV is not an easy format to work with.
And welcome to our forums.
Best Program to Remove Audio from VOB and insert another Audio
By Zhuge Liang in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2012, 03:42 -
Remove Sound From Original DVD And Add My Own Sound To New DVD.
By MrJacobAngle in forum Authoring (DVD)Replies: 7Last Post: 30th Jun 2010, 15:38 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
Remove extras and keep the original menus
By jujuandhuhu in forum DVD RippingReplies: 4Last Post: 7th Mar 2008, 09:55 -
How to remove Nero Showtime only
By lordmajax in forum Software PlayingReplies: 4Last Post: 8th Aug 2007, 18:46
