Does anyone know what the abilities & limitations of VSO ConvertXtoDVD? Will it take Video_TS files to DVD? Is it user friendly? Etc, etc...
I'm getting ready to start using it, however I haven't found a lot of information about how to use it.
Thanks...
Abilities -
ConvertXToDVD (aka DivXtoDVD) is a 1 click solution to convert your movie files to a compatible DVD playable on any home DVD player. ConvertXToDVD supports most popular format such DivX, Xvid, MOV, VOB, Mpeg, Mpeg4, AVI, WMV, DV and stream formats. It converts your single files into a compliant DVD Video set of files and burns it on a DVD media. Supports switchable subtitles from srt,sub/idx.
Not sure about it's limitatons as I haven't used it.He's a liar and a murderer, and I say that with all due respect. -
If you have VIDEO_TS files, you already have a DVD and you wouldn't need ConvertXToDVD. You could just use ImgBurn and burn the VIDEO_TS file to DVD media.
ConvertXToDVD is one of the best of the 'one-click' converters. It works well for converting Xvid, Divx video to DVD. Very handy for a quick conversion to the DVD format. You don't need a lot of information to use it, that's one of it's advantages.
But if you look near the bottom of the ConvertXToDVD page, you will see three guides listed.
And if you want more control, more options and possibly better quality, you should look into the individual tools, like standalone encoders and authoring programs. You will find guides for these operations to the left, 'CONVERT and AUTHOR'.
VSO Media Player - report - doesn't play anything
By Jeremiah58 in forum Software PlayingReplies: 1Last Post: 19th Aug 2011, 04:39 -
VSO ConvertXtoDVD is turning 155 mins into 95
By Calavera33 in forum Video ConversionReplies: 7Last Post: 25th Apr 2011, 12:32 -
VSO Blu-ray to DVD
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2011, 13:40 -
Slower encoding with VSO than it used to be
By Brainstorming in forum Video ConversionReplies: 8Last Post: 28th Dec 2010, 21:52 -
pc crashes with vso convertx
By dvdex in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2009, 19:40
