I am not sure which template. I want to make a vcd that can play full screen on my DVD standalone player.
Hello w4zzabi
You have to give us more information if you have any problem.
Anyway, If you have the knowledege to burn your own VCD, you know that sort of problem (which is't any ...
Learn trough the nice, and for the moment, free guides at this site.
Cheers// Radioman -
okay one of the problems is the my mpeg is like 300x200 and if i make a vcd out of it. Is that the size its gonna show on my T.V ?
If you use the standard resolutions (PAL 352x288 or NTSC 352x240) from one of the VCD templates then I think TMPGEnc will just convert the resolution for you while it's encoding.
Up-converting resolution is never very nice though and can take a lot of time.
VirtualDub can also do conversion resolution on AVIs. If it does a better job (opinions?) then you might want to do it with VirtualDub and then encode it.
Many DVD players just fill the TV with whatever they're playing as well so you might not have to convert it.
The bottom line is to experiment. A CD-RW is a good investment (believe me!) - then you can burn it once you've got what you want.
I know that was sort of all over the place but I hope it helped.
Varek
Electonics Engineering Technologist
Web Application Developer
Videographer Wannabe
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
