I'm attempting to make a backup of a dvd . Used dvd decrypter to rip it, and copy to dvd
to burn to disc. After decrypting it (all files), copy to dvd said there was no video_ts.ifo file and the burned dvd would probably not work. I used ifoedit to make video_ts.ifo and got no errors from copytodvd to burn disc. The burned disc will work fine in any computer's dvd-rom I can find but not in any standalone dvd players. I've ran across the no ifo problem before and corrected it with ifoedit and the resulted burned disc worked fine in anything.
the standalone players give an error message that says something like this dvd is not capable of playback.
the original disc plays fine in standalone players.
what am I missing?
(using the most recent versions off all tools)
DVDDecrypter has not been updated for over a year. Use RipIt4Me (used with DVDDecrypter) or DVDFab Decrypter to rip. Then use FixVTS to eliminate any problems. I then use VOBBlanker to blank out any of the DVD parts I don't want like "Making of ...". This helps eliminate info you don't want so when you use DVDShrink it will not have to shrink as much to get a 7+GB movie on a 4+GB DVDR disk. The less shrinking you do, the less blockiness, and greater quality you will get.
Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic -
Apparently, my problem was some bad blank dvd-r's . I tried burning the information
to a dvd from the bottom of the spindle and it works fine. The middle is fine too. The bad
ones resided at the top. You get what you pay for, I suppose.
Thanks to those who posted replies to my pathetic problem.
MKV to AVI to play in standalone DVD player
By AzzKickr in forum Video ConversionReplies: 8Last Post: 9th Sep 2011, 14:53 -
Standalone player will not play DVD
By Chala in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2010, 04:09 -
Edited DVD won't play on standalone 1yr old DVD player.
By Brooke2424 in forum Authoring (DVD)Replies: 2Last Post: 14th Sep 2009, 14:50 -
DVD doesn't play in standalone player
By descotes in forum Newbie / General discussionsReplies: 9Last Post: 8th Jul 2009, 23:57 -
Burned dvd won't play in standalone player
By Shotobits in forum Authoring (DVD)Replies: 12Last Post: 13th May 2008, 02:21
