hello All:
I've got some muxed mp2 files ready to convert to DVD using FFMpegX. I'm only using FFMpegX because I was given these files and they aren't compatible with iDVD. So the question is- is there anywhere within FFMpegX to do this and set the autostart and looping tags to create a DVD that loops? OR, is than a way to hand edit the resulting files in a text editor or do something while burning the final in Toast 5 Titanium that I could get the desired result?
I'm sure I could convert them to a QT format and then go that route, but would rather not take the time and/or fidelity hit of all the conversion.
Thanks....
Using Toast, it would be a single checkbox... can't beat that for simplicity.
Dvd with looping chapters...
By miksterr in forum Authoring (DVD)Replies: 2Last Post: 13th Aug 2010, 00:23 -
Creating a continuous looping DVD playlist from hard drive
By bryners in forum Software PlayingReplies: 4Last Post: 6th Apr 2010, 14:49 -
Is There A Way To Disable Autostart Recording In The Magnavox H2160MW9 ?
By wtsinnc in forum DVD & Blu-ray RecordersReplies: 10Last Post: 12th Jul 2009, 17:07 -
Windows Movie Maker AutoStart Problem
By kimco52 in forum ComputerReplies: 9Last Post: 25th Mar 2009, 10:25 -
Looping DVD with no menu
By SCDVD in forum Authoring (DVD)Replies: 7Last Post: 21st Feb 2008, 20:12
