I downloaded movies in .avi. Now I want to burn them as a dvd AND add also subtitles. I checked many sources as how to do this but those all concerned when ripping dvd's. Can anybody help me or give me the sources how to do this?
The main question, do you already have the subtitles? If so, a simple program like ConvertXToDVD can handle some formats of subtitles and create the DVD fairly easily. I use .srt format subs. If you don't have the subtitles, then the answer can get somewhat complicated. You might visit our Subtitle Forum for more information.
I've used Xvids that have separate subtitle files with ConvertXToDVD and it seemed to work well enough. The program seems to find them automatically. -
I have subtitles. I just download them from the net. I will try your suggestion.
any avi converter to add subtitles (like on / off) like we use in dvd ?
By ashe09 in forum SubtitleReplies: 13Last Post: 19th Mar 2012, 06:59 -
Add permanent subtitles to S/VCD,DVD,AVI with ffdshow/vobsub
By Baldrick in forum User guidesReplies: 74Last Post: 4th Oct 2011, 05:11 -
Add Subtitles To AVI From DVD Source
By Blue_3 in forum DVD RippingReplies: 9Last Post: 1st Sep 2008, 13:39 -
How to add subtitles to AVI?
By sepehr_s in forum SubtitleReplies: 1Last Post: 16th Apr 2008, 15:10 -
how to add subtitles to an avi file so that my dvd would read it?
By Arwen-Katie89 in forum SubtitleReplies: 8Last Post: 13th Dec 2007, 12:02
