I have a DVD that was made using a standalone DVD recorder. The structure must be corrupt. It will hardly play on a standalone player. And even on my PC it takes 2 minutes to initialize. DVDShrink encounters errors if you try to open the files on it. And Nero has the same problem.
How can I repair the structure?
OR
I am able to extract the part I want using smart ripper. But then how to I author that single VOB file back to a DVD with the correct structure?
I had a similar problem not long ago. I thought it might have been a CPRM problem but the disk doesn't play right in either of my players, not even the original recorder. None of the ripping tools I tried would do it either. IsoBuster pro (not the free version) was able to get most of it from the ifo, but there was still a small portion it couldn't get. Just a bad -RW disk I guess.
Re-authoring will not result in quality loss.
He's a liar and a murderer, and I say that with all due respect. -
That's correct.
Build DVD Structure without Menus and Create them Separately
By Bruno AUgusto in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2011, 13:50 -
how to link together 3 .VOB videofiles to create a single DVD
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2010, 06:27 -
How to create the file structure of a DVD video disc?
By mrpop151 in forum Authoring (DVD)Replies: 2Last Post: 16th Nov 2009, 12:51 -
question about VOB file structure on DVD
By jimdagys in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2008, 04:58 -
create dvd structure from a .vob
By forare in forum Newbie / General discussionsReplies: 6Last Post: 12th Sep 2007, 04:13
