I made an intro video for my companies DVD's and I want to post it on Youtube, but it has to be under 100MB, how do I compress it down to fit under that size? It is at 120MB at this moment.
I've never tried posting anything to YouTube but regardless you have two options.
Use a lower bitrate or cut some of the video out.
To be able to provide more useful info on how to do either you need to provide a lot more detail about the video. How about a gspot screenshot?"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
You might take a look at ReJig. It works similar to DVD Shrink to reduce the size of a MPEG-2. It should be faster than re-encoding the video, especially if you just need to reduce the size a little.
If it is beig uploaded to YouTube then they will convert it to FLV anyway, so you probably on't need to spend money doing that yourself.
Below are YouTube's recommendations for file formats for upload
# Videos saved with the following settings convert the best:
* MPEG4 (Divx, Xvid) format
* 320x240 resolution
* MP3 audio
* 30 frames per second framerate
You can use autoGK to do this for you.Read my blog here.
compress video
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2009, 03:43 -
Compress video in Vegas 4 for Weepies video
By Knightmessenger in forum Video ConversionReplies: 3Last Post: 7th Jul 2008, 00:04 -
Compress Webcam Video Stream (Video Conference)
By wxrkny in forum Newbie / General discussionsReplies: 1Last Post: 5th May 2008, 23:11 -
mpg...compress and chop
By astro604 in forum EditingReplies: 3Last Post: 1st Mar 2008, 18:50 -
how do you compress video
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 13:21
