Let's keep this one to ourselves, as it can serve as a cool holiday gift. It won't be cool if everybody knows about it, though. Please don't post the url around until January, 'mkay ?![]()
http://homokaasu.org/rasterbator/gallery/i/2858.jpg
http://homokaasu.org/rasterbator/gallery/i/9251.jpg
http://homokaasu.org/rasterbator/gallery/i/242.jpg
Upload your image to the online app and tell it your desired dimensions (ie a living room wall). It then upsizes the picture to a mosaic like series of 8.5x11" sheets of paper - all contained in a multi-page PDF file. Print the PDF out, and voila - you're Sandy Warhol. Owners of Inkjet printers, get ready to be depletedUse good quality paper, otherwise the saturated portions of the image will have a tendency to curl and bubble as they are drying from the massive amount of ink applied to them.
Results 1 to 13 of 13
...or better yet, get the downloadable version and do it all offline and avoid the bandwidth hassles and time lag.
Scott -
PosteRazor makes big poster.
Rasterbator makes big poster size artwork. -
Another idea would be to have a printing company do the job.
Here is a link to the price list at BigPosters.com
http://www.bigposters.com/pricelist.jpg
Another idea..... Print your own, but print VERY light, barely able
to be seen. Then paint over the papers with oils or acrylics.
Seems like the pro printers would be the cheapest. They can also
use UV inks.
"Technology is getting smarter but people are getting..."
"A person who has everything really has nothing"
Did you know "alot" isn't a word? -
Let's take it one level further.
http://www.skywriter.info/skywrit_gallery.htm
Now THAT is a brilliant idea, especially for one of the smaller posters. Thanks. -
I'll go off-topic a bit....
Trompe Loeil is something that is interesting, and can be done
the same way that has been discussed in this thread....
...but on a smaller scale!!
John Pugh is a master. The 2 photos below are his work.
They are painted onto the buildings, including shadows, highlights, people, etc.
(The columns are PAINTED onto the building!!!)
Pugh's site is here...
http://www.illusion-art.com/default.asp
Another Tromp Loeil master is Yves Lanthier.
Here are 2 links to before and after photos.
http://www.yvesart.com/DomeBefore.htm#Before
http://www.yvesart.com/DomeAfter.htm#Dome%20After
Lanthier's site is here...
Here are the examples of John Pugh's work...
Kinko (in U.S.) suppose to be a place to able to print at large poster size with a fee, but their web site is horrible on info, on size, cost, file type...
Anyone has any success with Kinko ? -
I have to post here once more because I found some more stuff!!!
The following link shows how to make large posters with iPhoto.
http://www.mikematas.com/2005/01/how-to-make-life-poster.html
I don't have a Mac and don't know if you can use it on a Windows PC.
I didn't have time to read his entire blog.
Edit...... This program might work for Windows.
Didn't have time to read it all.
http://picasa.google.com/"Technology is getting smarter but people are getting..."
Reason they don't post the pricing is because it's intimidatingly expensive. However if you consider the costs of some ink cartridges for home printers to piece together a large poster versus just printing it at FedEx Kinko's on a single sheet (60" wide by up to 100' long) then the cost may be justifiable. Just make sure to have either vector art (best) or high resolution image (200dpi minimum when sized). Costs are about $10 per sq-ft for paper, $6 per sq-ft for this poly material that sometimes works (best used with line art rather than photos), or $12-15 for premium papers and canvas. They have a watercolor-texture paper that sometimes looks really cool when combined with the right photo and a well-placed watercolor filter. Some of the specialized sign places for Kinko's (only a dozen in the country so far) have machines that will print full color directly on foam-core or even metal, plastic, and wood as long as it's less than 1.75" and has the right smooth surface to print on. The UV dye VuTeks rule 8)Originally Posted by SingSingFB-DIMM are the real cause of global warming
I downloaded the Rasterbator program but when I open up the folder and click the rasterbator icon I get a message reading:
'the application failed to initialize (0xc0000135). click on ok to terminate the application'
I think I need .NET framework but im not sure what that is and dont know if its compatable with SP1 -
Yes, you need .NET framework. You can download it here
It should be compatible with SP1, but the easiest way to find out is to try...In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
Nothing too new really, CAD programs usually have printing options that allow for "Tiled" printing.
I have seen full sized vinyl stickers printed/plotted out for layout of some "tricky" construction elements and used as templates for sign lettering and such.
I kind of kick myself for not getting in on an oppertunity to print out vinyl graphics for advertising. How was I supposed to know that the guy would land an account for McDonalds. (Bummer)IS IT SUPPOSED TO SMOKE LIKE THAT?
Alternate Method for Creating Poster Frames for Quicktime Movies???
By m021478 in forum MacReplies: 2Last Post: 11th Dec 2011, 17:06 -
The poster above you thread.
By AND1 in forum Off topicReplies: 3585Last Post: 7th Mar 2009, 00:16 -
How to create album art for Movies?
By siratfus in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2008, 06:23 -
Watch movies online with other online also at the same time?
By Ghtpua in forum Software PlayingReplies: 5Last Post: 11th Feb 2008, 14:02
