I'm trying to get rid of the last Imation DVD-Rs I've got, so I'm just regulating them to special features that won't fit on the main (Verbatim) disc.
I haven't watched all the Imation discs yet, but some pixilate. And sometimes it's not that bad on a disc, other times it's unwatchable. But all in all no great loss, but I don't want to waste them, either.
I believe it's the quality of the media and the speed I'm burning them at(8x). I've yet to have a problem with burning the Verbs at 8x, but they're overall better anyway. Am I correct in my assumption?
Thanks in advance.
I think those assumptions are too broad. The name on the disc doesn't usually mean much. What is important is the manufacturers code. Some disc companies have the same version disc made in different locations, by different manufacturers. And even with that, the quality can vary by batch. If you check the manufacturers code and see what that manufacturers track record is for quality, then you may be better able to judge one brand from another.
lordsmurf has a site about DVD quality that has a lot of good info: http://www.digitalfaq.com/media/dvdmedia.htm
And Slamtastic, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
And since this is a media question, moving to our Media Forum. -
some drives burn certain media better at certain speeds. verbs +16x burns best at 8x in my pio 111 but liteons burn them better at 12x. in other words... you'll have to do a scan (nero etc) to figure out what's the better speed.
graphic quality differences
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 5Last Post: 27th Jun 2008, 14:51 -
Best Buy Verbatim - 50-Pack 16x DVD-R Disc Spindle $12.99
By sknox in forum MediaReplies: 5Last Post: 16th Mar 2008, 20:46 -
Verbatim +R DL for under AUD$5/disc ?
By guns1inger in forum MediaReplies: 10Last Post: 2nd Nov 2007, 19:37 -
Differences picture quality with DVD player with HDMI port ?
By Roccos in forum DVB / IPTVReplies: 4Last Post: 25th Sep 2007, 11:24 -
Quality differences on older machines?
By Ikasu in forum DVD RippingReplies: 7Last Post: 9th Sep 2007, 17:37
