Just like it says in the title. Got this because my Panasonic DMR E55 died. It was always finicky, it was getting so that I would have to bang on it so that it would be able to accept the blank dvd put into. It was always going into standby mode. I got the Philips from Wal Mart on Saturday, it occurred to me there was no pause on this. I guess I could stop it for every commercial break and it could make a new chapter, but is there a smoother way to get rid of all the commercials from tv shows?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
The only way I found to delete is to make a chapter mark before and after the stuff, then delete the chapter... takes about three minutes, each item, because every time you hit the edit button it goes back to the beginning of the disc.
-- Geo :: I play ALL my * .AVI files on my Philips DVP642 !!!
Save your URLs and share URLs -- FURL your links at http://www.FURL.NET/ -
But, there IS a pause button. You can hit pause -- the button looks like || -- and then REC. Works great, especially saving TiVo content.
Ya, I found it like an hour after I posted on here. I had to read the manual, and go in deep, they really don't tell you some of the functions on the remote legend. So if you don't really need to use the pause for your recordings, like just when you record movies, you wouldn't have known about it.
Delete commercials keeping the right timing of the subtitles on a MPEG TS?
By edea in forum DVB / IPTVReplies: 4Last Post: 21st Oct 2011, 18:19 -
How do I turn off on-screen pause icon on the Philips BDP3000?
By alexh110 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Dec 2010, 21:55 -
Philips DVP3260 and strange Play/Pause behavior
By Jagg1010 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 11th May 2010, 18:23 -
Philips DVDR 3390 won't let me fast forward DivX movies
By guiri in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Sep 2007, 04:28 -
Philips DVDR 3390 - Can I capture to a PC with this recorder?
By muzicman82 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Jul 2007, 18:32
