ive been burning with shrink for awhile and only recently close to the end of the burn a log says svs type set to dvd-rom
does anyone else have that while finishing up a burn....and do i need to change it?
When you burn a DVD+R some DVD burners (not all) can do something called BITSETTING.
In short a DVD+R can be labeled in the header info as a "DVD+R" or as a "DVD-ROM" and you always want it to be set as a "DVD-ROM". Setting this "header info" is called BITSETTING.
DVD-R does not have this issue.
Anyways ...
I am guessing based on your description (by the way you need to hone your grammar skills big time) that you are burning to a DVD+R and that DVDShrink is setting it to a "DVD-ROM" but since I avoid DVD+R discs like the plague I really can't say for sure.
As a side note ... you really should be using DVDShrink to output to a VIDEO_TS folder only. After that you close DVDShrink and use ImgBurn for burning. This will give you better results than allowing DVDShrink to do it all. And no don't let it create an ISO IMAGE file either. Do that and the burning with ImgBurn.
Info here:
http://www.cdfreaks.com/reviews/Increased-compatibility-DVD-bitsetting.html
regards
Pol -
Originally Posted by FulciLives
To be more accurate, DVD-R lack's this advantage.
And what's wrong with making an ISO & burning with ImgBurn instead of letting ImgBurn use a VIDEO_TS folderOriginally Posted by FulciLives
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 22:24 -
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 09:33 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 16:39 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 16:59
