Hi everyone,
It's Marissa again. I'm really new to this whol,e burning dvd thing! Can someone give me the name of a converter that will convert the mpg files and then burn them to dvd? I tried to use tmpgenc, but since I am blind and use a screen reader, the interface is not interpreted correctly. Can anyne recommend a good program? With a simple to use interface? Thanks a lot! Have a great day!
A simple converter is ConvertXtoDVD. Fairly simple interface as well, so hopefully your software can read it.
If your mpg is already DVD compliant then all you may need to do is author it. You can read about compliance here -> https://www.videohelp.com/dvdRead my blog here.
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 18:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
