Anybody noticed that when they encode a 4:3 video (SVCD) and try to play it back on the 440/444 you never get the full picture??
If I tell the DVD the TV is 4:3 and I want it normal, it adds black lines! (even when Bitrate is reporting the source is 480x480 at 4:3 NTSC!) So when I say the source is 16x9 and I want to crop, it shows full screen, but the video is not complete (about 10 lines on each side are missing).
Anybody else got this?? How do I fix it?? The source is record as 4x3 from TV.. I use virtual dub with the only filter being to convert to 480x480, leave interlaced, and use precise bicubic.. and I then use CCE 2.50 to convert it to MPEG2 file (min 1900, avg 2300, max 2520). I then use TMPEG to create the 192mbps audio stereo file, and lastly TMPEG to combine the audio/video and nero to burn (SVCD compliant).
HELP!
JoeB
P.S. When I play the video in WinDVD or PowerDVD, it shows the full video.. and it reports the file type is SVCD 4:3 NTSC video.
P.P.S. I burn with the latest Nero version, and it tested the MPEG2 and said it's compliant!
Osprey 440 card capture video in mp4 from live stream
By vrparekh@gmail.com in forum Capturing and VCRReplies: 1Last Post: 13th Apr 2012, 06:21 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
Pioneer dv-400v XVID playback problems
By ironzenmountain in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Sep 2008, 00:22 -
Pioneer DVR 630 HS - Recording will not playback
By ktmsprocket in forum DVD & Blu-ray RecordersReplies: 3Last Post: 14th May 2008, 13:06 -
Pioneer DVR-440 or Toshiba XS35 (85DT?)
By StuR in forum DVD & Blu-ray RecordersReplies: 33Last Post: 5th May 2007, 13:38
