....specifically, uncompressing it back to original raw DV quality?
I've searched around Google and the site here and did not see an answer, but similar questions about VOB files.
I'm starting to think that it cannot be done. (perhaps, unless the original mpeg-1 codec is on the same PC/compressing application)
I am trying to take a cell phone MPEG1 file and was hoping to make it better.![]()
Not as far as im aware. Once you compress a file to MPEG1 you take out (loose quality) bits of information to compress it . So the information you want to add back in is not actually present in the MPEG1 file you have.
You would need the original file and need to compress that to improve the quality. -
You can't get back what you don't have.
About the best you might do is do some light filtering and make it look a bit smoother. But you will still have some conversion loss. You could use VirtualDub Mod and convert it to a lower compression format like DV by adding the Panasonic DV Codec. Then use some of the hundred or so VD filters available. Some are here: http://neuron2.net/
But I wouldn't expect too much.
What format do you want to end up with? -
Thanks guys. I get it. I guess I was hoping for some "reverse engineering" if you know what I mean.
lol. Run the CODEC backwards and you get back lost bits, right??
Any format will work for me, I was just hoping to create a better finished quality. Well, significantly better that is.
I can go ahead and use it as is. No big deal.
Thanks for the quick responses!
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36
