How do i burn this to a dvd? ( its a movie)
the first file is 2 gig, 2nd file is 2 gig and third file is 12megs and mds file is 5kbs....Is this suppose to be an iso?
can you give me instructions how to do it?
When I go to IFO-Write , I can only select the MDS file... -
ImgBurn may be a little simpler for burning the image. Just drop the .mds file into the 'DVD Root' Directory line and click 'Burn'. There should have been a .mdf file in your un-rared folder, also. That's the video file that gets burned to disc. The .mds file is just the 'instructions' for the burning program. Those are Alcohol 120% image files, BTW.
That format you describe doesn't sound right. There should be only one .mds (About 5K) and only one .mdf which would be the movie. .mds/.mdf files are more common for CD burning.
EDIT: OK, I found an explanation. You should be able to select the .mds file and it should burn the whole thing as a single file. Just select the .mds file in ImgBurn as mentioned and let the program sort it out. The file may have been made on a FAT32 system with DVD Shrink and it split the ISO into 3 parts. Explanation here: http://www.digital-digest.com/articles/dvds_iso_mds_files_page1.html -
Thanks a lot, i'll try it now....if it doesnt work, i'l repost...Thanks for your great help
How do I burn an I00 file
By t_jay17 in forum Newbie / General discussionsReplies: 31Last Post: 10th May 2012, 16:09 -
Img Burn software Where does the DVDIMAGE.MDS file go??
By orfajackson in forum Newbie / General discussionsReplies: 0Last Post: 26th Jul 2009, 14:46 -
Converting I00, I01, I02 etc
By absurdism in forum Newbie / General discussionsReplies: 7Last Post: 30th Jun 2008, 20:21 -
HOW TO BURN Ps2 games MDF/MDS on MAC OSX
By kimkimkimmykim in forum MacReplies: 7Last Post: 2nd Nov 2007, 03:52 -
Making an Iso from an I00 file
By t_jay17 in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 16:50
