Hi
I run on my computer DVD (from the dvd drive) with microsoft media player. this DVD has close cuptions only I downloaded subtitles in srt format. How do I run the dvd and read the subtitle from the srt file?
I use Vobsub and I don't want to copy the dvd to my computer.
Thanks,
ami
You can also do this with SubtitleCreator (Help->Manual for instructions).
Cheers
Manusse -
Hi-
To have the subtitle play 30 seconds earlier, open the IDX in Notepad and add this just above the first timestamp:
delay: -00:00:30:00
If you want it to play later, remove the minus sign. Now, that works with DirectVobSub, but I don't know for sure that it works when using DVDSubber (having never used it). If not, and if a negative 30 second delay is correct, then open the IDX in Sub Resynch (comes in the VobSub package), and then save it as a new IDX. That will erase the typed in delay and change all the timestamps. -
Srt, not vobsubs though. You could use something like Subtitle Workshop to delay the subs.
Media Player Classic I believe can also play DVD's with external subs. Should also be able to delay them. -
If you are using SubtitleCreator to preview your subs, you can also add the delay needed and check the result immediately.
Cheers
Manusse
Subtitle Editor Linux - How to Run It on Windows 7?
By devilcoelhodog in forum SubtitleReplies: 3Last Post: 27th Feb 2012, 19:42 -
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 14:31 -
tmpgenc dvd author 3 cant read arab subtitle
By TheEmperor in forum Authoring (DVD)Replies: 6Last Post: 3rd Oct 2009, 09:07 -
Help Friend! How to read subtitle file on my dvd player (not divx supported
By justin1983 in forum SubtitleReplies: 17Last Post: 26th Jan 2008, 12:42 -
How to read this subtitle file?
By moviebuff2 in forum SubtitleReplies: 13Last Post: 24th Aug 2007, 16:36
