Hello.
I have about 20 video files that are ready to go onto the internet, but before i put them on the internet i want to add something just in the first like 10 seconds of the video, a little watermark down the bottom corner with my website address on it or something like that. Or even just add 10 seconds to the beginning of the movie with just a screen with my website address on. But i don't want to have to encode them all again as it would take forever. Is there a way just to add it in that won't take forever?
the video files are .avi and are sized 560x320.
thanks.
Results 1 to 12 of 12
Nope. To add the watermark you will have to re-encode. If you use something like virtualdub you could cut the video at an I-frame, add the watermark to just the first (shorter) part, re-encode it, then join the two parts together again. Probably easier to just re-encode everything or skip the watermark altogether
Read my blog here.
Originally Posted by wwfc_barmy_army
try this link it will help you solve your problem i think
https://www.videohelp.com/forum/viewtopic.php?t=248307 -
Originally Posted by TheTrueBlue
Ok, i just did that but it hasn't included the watermark. I have the screen up and it have the original on the left and the watermarked one on the right, and then i go to save as etc. What else am i meant to do to get it to include the watermark?
Make sure you are in Video -> Full Processing Mode. No filters are applied in any of the other modes.
Ok thanks. But i have just tried watching it but all the sound is out of sync. Any ideas why??
Software Similar To ConverXDVD
By niteghost in forum Authoring (DVD)Replies: 3Last Post: 30th Jan 2012, 15:11 -
something similar to Cellulo for MKV?
By DarkPhoenix77 in forum MacReplies: 4Last Post: 27th Jan 2011, 15:37 -
4:3 to Letterbox (or Something Similar)
By christopheramos in forum Authoring (DVD)Replies: 2Last Post: 23rd Aug 2008, 02:57 -
Similar players like The KMPlayer or better...
By chalava in forum Software PlayingReplies: 6Last Post: 29th May 2008, 13:04 -
ffmpegX and similar converters
By febras1982 in forum Authoring (DVD)Replies: 0Last Post: 27th Nov 2007, 10:02
