I would like to create clip which starts from full screen movie, then it starts to shrink, circles around the screen and then sticks as a thumbnail on the background. Then the next movie starts, circles and sticks near by then another and another...
I want to create this clip to use it in a menu, but my question is not about creating the menu.
Cann't tell it's possible don't tell anything.
Wax supposedly can handle it , but buggy ... save often .
To get the type of motion you want , you would need to use "key frame" method .
I have several projects that use jpgs , that do all this ... and they take alot of time ... as well , they are used for dvd menu's . -
Nice program, thanks. Realy does what I want. I went through the tutorial - it is realy easy and comfortable program. But I skipped creating the nice menu. The main problem is to find and prepare right assets for the menu. I already spend day to deciper performers in total of 4 hours of video, so I just made 24 sec. motion menu with 6 thumbnails and music in the background with TMPGEnc DVD Author.
Cann't tell it's possible don't tell anything. -
Premier Pro or Avid will do this. Just make the clip match to a DVD MENU, and at TIME X after all the clips have rotated on and set back in position, disovle out to the actual thumnails that launch the movies from the menu, already in MATCHING POSITIONS
Sync/align one short clip into one big clip
By diamondback in forum AudioReplies: 1Last Post: 2nd Nov 2011, 10:31 -
Converting a Clip
By amerifax in forum DVD RippingReplies: 6Last Post: 30th Dec 2008, 01:11 -
Transition from Clip to Clip in Premier
By Namrepus221 in forum EditingReplies: 2Last Post: 1st May 2008, 17:29 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 09:26 -
I need music for sport clip, can anyone help?
By Sean_ve99 in forum EditingReplies: 1Last Post: 23rd Jun 2007, 19:44
