Hi all I am using a Sony DCR 109E camcorder and a Sony DV tape. I have footage of my son being a day old. When I play it back through the TV, PC and my freinds PC I hear a popping sound but most of all the audio fades all of a sudden as if i dubbed out a word, this only lasts for a slpit second and the audio then returns to normal, a few seconds later the dubbed effect then reappears and it lasts throughout the hole entire hour. It is very annoying.
So any ideas on how to repair/clean the tape itself? Or do I count my losses.
Thankyou in advanced Josel
Count your losses. You could possibly go through and ampllify each drop out to attempt to match the rest using a audio editor like Audacity or Cool Edit, but the results probably won't be as clear as you'd like. Does this happen with everything you tape or just this one? Did you do the taping yourself or did someone else do it? Without more details of how the video was made, I suspect a problem with the built in mic and how the camera was handled while filming. It's possible that the mic solder joints are bad and that holding the cam at certain angles or vibrations can cause it to lose connection momentarily. Experiment and see if you can duplicate the problem, then try an external mic and see if the problem disappears. If so, exchange the camera or repair under warrenty.
Buy My Books
Audio & Video fades
By rearadmiral in forum EditingReplies: 2Last Post: 1st Nov 2011, 12:29 -
Subtitling Program That Can Do Fades
By SLK001 in forum SubtitleReplies: 0Last Post: 18th Mar 2011, 22:33 -
Fades in VideoRedo?
By dadrab in forum Capturing and VCRReplies: 3Last Post: 4th Mar 2009, 15:00 -
Soundlevel fades in backup of DVD
By ClaudiuS01 in forum AudioReplies: 7Last Post: 20th Sep 2007, 22:47 -
audio fades in and out during after capture
By grmpy in forum Capturing and VCRReplies: 0Last Post: 6th Sep 2007, 22:05
