  1. I heard that you can play VOB files with WM Player with Nimo's codec pack installed, but if anything goes wrong, you system is really messed up. Any truth to that?
  2. i tried Nemo's codec pack. it screwed up some things on my machine that took a while for me to fix.....
  3. You should be able to play VOB files w/o Nemo's Codec pack (give it a try). IIRC all you need as any MPEG2 codec, and I'm fairly certain I've played them on systems w/ no codec installed.
  4. Vejita-sama, i think your right. i think after i installed a Mpeg2 codec i was able to watch Vob files.......
