Hi guys!
I was wondering how I could adjust my screen resolution so I can make it smaller.
Does anyone know what I need to do?! Any help would be great!
- Oh, I almost forgot, I uploaded a Word file with a pic of my display properties in it for you
- Also, I have a Dell Inspiron 600m
http://www.dell.com/content/products/productdetails.aspx/inspn_600m
Thanks!
Jenny
jennydisplayproperties.doc
Can you download the manual to your computer and actually read it.
I put a link to it in that other post you made.
That manual should have the answers to all your questions.
- John "FulciLives" Coleman
P.S.
No one worth his/her salt is gonna open a DOC file from an unknown source. Could be a virus. If you want to upload a picture then read this: CLICK HERE"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
you're kidding right
Look in your "Control Panel".......
Hint: start button. -
You have a laptop - there isn't much you can do. Most LCD displays on laptops use the whole thing even if you drop the resolution. e.g., if the native resolution of the display is 1024 x 768 and you choose 800 x 600 via Windows, it will still take up the full size of the display and look quite awful.Originally Posted by JennyJohn Miller
Right click on screen then left on Properties, then go to settings tab. There you have screen resolution. The bigger the numbers get the smaller things look infact you increase resolution to fit more on the screen.
Hi guys.
But my problem is the highest my screen rez says it can go is 1024 x 768.
Can I put a new video card in a laptop. I know this may sound stupid
, but I really don't know!
Any help is appreciated!
Jenny -
Very difficult to impossible in a laptop to upgrade the video card.Can I put a new video card in a laptop.
If you go to your Display>Settings>Advanced>Adapter>List All Modes, that's all the selections available for your card. But your laptop display will work best at it's native resolution, which is probably 1024 X 768. Any other size won't look good. However, you can click on your 'Monitor' tab and uncheck 'Hide modes that this monitor cannot display' and you should see some other resolutions. That doesn't mean you can display them, though. And read the cautions below that checkbox.
I think the real question is: Why do you need to make it smaller? -
Hi guys! Thanks for all the posts...and yes, I'm not reading the Manual like it's the last newspaper on earth.
redwudz...you hit the nail on the head I think...I followed your instructions to a tee and I could not get past 1024x768...however, I could "see" more options following your detailed post.
Anyway, thought I'd give it a chance...thanks very much...and be sure I'll be back!
Thanks guys!
Jenny
making mkv smaller
By jetli68 in forum Authoring (Blu-ray)Replies: 2Last Post: 21st Sep 2011, 12:31 -
Making a 1 gig HD wmv file to smaller portions
By OzzyWeb in forum Video ConversionReplies: 5Last Post: 28th Mar 2010, 12:10 -
making an avi file smaller to burn
By enigmatic620 in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 09:29 -
Making file smaller in Adobe Premiere Pro
By JustinBaker in forum EditingReplies: 2Last Post: 18th Sep 2007, 16:07 -
Help in making MPEG-2 files smaller with encoding
By screwed in forum Video ConversionReplies: 4Last Post: 20th Jul 2007, 04:23
