i have a LG 4163b burner
recently bought a 50 pack of ridata 8x dvd-r (the ones with a blank surface and no logo cause i couldnt find any other decent media at any of the stores)
and i noticed that the burner (although burns fine to the media) refuses to see the disk after the burn is done (movie - mpeg2)
my dvd rom drive (also LG) cant see it either
they both act as if there is no disk in the drive
however my consumer dvd player DOES see it ! ?
whats up with that?
i mean, it obviously buens the movie, but why cant either drive see it?
I and others have had similar problems with -R media in NEC drives, and Ritech G05 is well known to be crappy media which is what I think you have from your description. I suspect your LG may have similar problems, and I recommend stick with quality media such as TaiyoYuden and Verbatim. NewEgg often has very good prices on DVD media if you don't find quality media in local stores.
Quality of burned disk question
By 81artmonk in forum Authoring (VCD/SVCD)Replies: 0Last Post: 21st Dec 2010, 20:26 -
Dvd recorder won't played burned disk
By 81artmonk in forum DVD & Blu-ray RecordersReplies: 13Last Post: 14th Aug 2010, 05:40 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 16:35 -
What makes a NEC3500 dvd burner stops reading burned cd's
By joy in forum ComputerReplies: 8Last Post: 1st Dec 2008, 17:19 -
Is there a problem with my DVD Burner? Blank Disk after a Burn?
By nadizo in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 03:18
