Closed Thread
  1. Hello,
    I was wondering what exactly is the difference between a codec and a directshow filter.
    As I understand it, a codec is something that codes and decodes audio/video information to and from a compressed / coded version and directshow filter is something that renders decoded information on the screen. If thats indeed the case, I guess there can be one layer of directshow over the codec ie. different codecs for different formats but a single layer of software to render the decoded information. Why is that I come across different filters like Xvid directshow filter etc. hows it different from the xvid codec ?
    am I wrong in what I think. I'd be grateful if someone can enlighten me ?
    Also, some codes have .acm extension while some have .ax while others may also have .dll. Can someone tell me what exactly is the difference ?
    thank you,
    regards,
    -puneet
    USA
    One post per subject is enough. Please don't double post.
    Continue here: https://forum.videohelp.com/viewtopic.php?p=1606295#1606295
    Moderator redwudz
