Question, is there any way to rip without alot of the in between steps to the final burn????? I am using SmartRipper, then to DVDtoAVI, and to TMPG, then onto the burner it goes (which is the HP internal computer one). I noticed that after the first step it is a VOB file, is there any way to rename it off the bat so the burners software will take it?? 'Cause I have to use the MyDVD software that came with it and it has to see either MPEG or AVI files for it to burn. Any suggestions?????????
if i'm not mistaken i think DVDX can rip and convert. i've only used it once and i wasn't to happy with the end result............
AVS File Steps
By sambat in forum Video ConversionReplies: 23Last Post: 16th May 2011, 13:27 -
First Steps In Premier CS4
By Sundayarak in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2010, 19:09 -
Convert subtitles online in only 3 steps
By countedmond in forum SubtitleReplies: 0Last Post: 28th Oct 2008, 12:27 -
Steps to ensure best video shoot
By bowmah in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2008, 22:17 -
Which steps should I use?
By Belfour in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 09:33
