Hi! I'm new here.
May i know, how to combined a ready sub script that is using sub station alpha and a video that have no subtitle.
Results 1 to 14 of 14
Hi-
The answer is yes, it can be done. However, do you want the subtitle to be selectable, to be able to be turned on and off, or do you want to "burn" the sub into the video? And in what format is the video? Is it, for example, some sort of AVI, or is it some sort of MPG, such as a DVD? -
The video format is in avi but i want to add the subtitle in it.
The subtitle for the video is ready and have been save in .ssa format.
Currently it's separate, i just want to know how to combine this both and i do not want the subtitle to be turn on and off. -
...but you have to reencode, throwing some overall quality out the window.
Why not keep the subs as a separate file (preferrably in .srt format, as that is the most supported format in both software and hardware players)? Preserves both time and quality.
/Mats -
If upgrading the quality video. Can't i just re-convert the data to a new data?
Originally Posted by Tetsuya
If like that is the problem. Then how do i preserved the quality of the video in what ways?
By doing nothing to the video. That's the only way. If you want permanent subtitles, you have to reencode, which means losing some quality.
/Mats -
To preserve quality there are only really two possible paths.
1) Leave it.
2) Use a lossless codec.
To have hard encoded subs AND keep quality only 2) is a possiblity and the size will probably increase massively.
Quality loss and perceivable quality loss are two different matters though.
Use AVISynth and textsub, re-encode and see what you think. The fact is that some ssa effects aren't really suitable for realtime playback, especially if talking non PC based playback. -
Then, What about the turning the subtitle on and off part.
Since, i also want to know. -
/Mats -
Program to tell you the combined length of mp3 files?
By branch in forum AudioReplies: 2Last Post: 6th Oct 2010, 21:20 -
removing a combined frame.
By fred3f in forum EditingReplies: 11Last Post: 19th Jan 2010, 21:38 -
ssa titles size 28 in Video Dub still small , why?
By vitalspec in forum SubtitleReplies: 4Last Post: 10th Dec 2009, 05:51 -
Combined movies different Frames Per Second FPS
By lindylex in forum EditingReplies: 2Last Post: 4th Jul 2008, 19:33 -
When i join ssa+avi the video is messed up
By noskid21 in forum EditingReplies: 3Last Post: 17th Jul 2007, 13:02
