HI,
just a quick one. I have just purchased a Loewe lcd pannel and have been watching dvds through euro scart. now that I have upgraded to component I am getting a black edge down either side of the screen. My dvd player is not an upscaling version so is this to be expected?
OH by the way I am not getting confused wit 16:9 and 4:3. the lines I am talking about are very narrow and are gone if I go back to euro scart
cheers,
benny
so maybe the scart was a compromised picture and the component is true to size?
on The Fifth Element I get the normal horazontal lines top and bottom but now I get a thin 1cm line down each side ( this was 2cm down one side but I used pic. geometry to even it up). On a 16:9 dvd such as buffy or angel I just get the thin lines either side -
Yeh I thought that too. I went back through the connection wizzard and repeated my set up
but nothing changed. Also checked the dvd set up again just to be sure. My dvd player is a Yamaha pro scan but it is a few years old and it was a cheap model. The tv manual does suggest to use pic. geometry to make the picture fit best when using HDMI, Component or XGA/VGA so maybe it comes back to the player. I am using Monster cables. Nothing else I can think of....
Replacing component on DVD recorder help!! Please!
By weenie02000 in forum DVD & Blu-ray RecordersReplies: 17Last Post: 7th Sep 2009, 08:05 -
List of DVD Recorders with Component Inputs
By rba46 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 7th Feb 2009, 22:00 -
DVD Player that upconverts thru Component
By cippalippa in forum DVD & Blu-ray PlayersReplies: 6Last Post: 8th Nov 2007, 17:46 -
HD DVD player with HD-ready HDTV component only
By hbecs024 in forum DVB / IPTVReplies: 14Last Post: 24th Jun 2007, 00:55 -
1080i Upconverting DVD Player Through Component Inputs
By Teutatis in forum DVD & Blu-ray PlayersReplies: 5Last Post: 16th May 2007, 00:16
