Got given an older, but good professional scanner, a Umax Powerlook 3. Trouble is, this generation of scanners uses a scsi port/controller card to connect to the expansion slots on the motherboard. Lo and behold, I find that the slots on my board are the 32-bit pci slots of todays generation, and the scsi card I have with the scanner has the older connection slot (i forget what they're called). So, am I buggered and should I trash this very decent scanner, or are there scsi cards with the old style parallel ports that can plug into the 32-bit slots of todays computers ?
Results 1 to 14 of 14
I've got an old scanner that has a SCSI interface, along with the bulky cables and a older PCI SCSI card. I believe those are called 'Centronics' plugs, with 50pins., similar to some of the older printer plugs. You may also need a termination SCSI plug unless the scanner has built in termination.
You may find a SCSI PCI card at a computer junkyard or a place like this: http://www.pacificgeek.com/product.asp?ID=30366&C=204&S=994 The older style of computer slots are probably ISA. Some cards may need an adapter from 25 pin HD-sub to 50 pin Centronics.
Unless it's a really high quality scanner, I would just spend the money for a newer USB scanner. My USB unit does just as well, but with a lot less bulk and size. -
You have an ISA card.
I had a professional SCSI scanner back in 1993 or so. It was crap compared to even cheap USB2 scanners of today. I actually still have the old scanner, it's in the garage, to be taken to a computer recycler later this month or next month!Want my help? Ask here! (not via PM!)
Yes, you are both right, it is an ISA card, actual numbers UDS-IS11 PC/ISA. So basically I'm looking for a scsi card with the same (25 pin) outlet, but with the 32-bit PCI interface (instead of the ISA) of today's slots ? , if there is such a thing ?
If its an easy solution, then I'll go for it cos the scanner Umax Powerlook 3 , is a very good one with trannie scan head for large format negs also, with I suppose is not cheap nowadays. Otherwise, as you say bin/ donation etc . -
My first scanner (a Microtek model) was a SCSI version and I had an ISA SCSI card for it.
Wow that seems like ages ago LOL
By the time you have to spend money on a card, you could just buy a newer and faster scanner.
About a year or so ago I bought an Epson Printer/Scanner combo that was on sale for like $80 at Staples.
Works well for me.
I finally found my SCSI controller card. It's a Adaptec 2906. It's a PCI card with a DB-25 external connector. That went to a DB-25 male connector and about 8 feet of SCSI cable to a CN-50 Centronics connector on the scanner. A active termination plug is on the other SCSI connector of the scanner.
I also had a 200MB Magneto-0ptical drive plugged in between the computer and the scanner at the time I was using it. I remember paying about $500US for the card, cable and the Umax Vista S-6E scanner when it was new. I used it with a Macintosh computer. The Canon USB scanner I have at work now cost about $50 on sale.
The Umax is a good scanner. I'll probably stick the SCSI card into one of my computers and use it for a couple of more years. -
Originally Posted by fulcilives
Wow that seems like ages ago LOL -
Another option is a USB to SCSI-2 adapter, although I believe the transfer is limited to USB1.1 I saw them sometime ago on Newegg.
As an aside, I still have a working HP Scanjet 4C that I bought over 10 years ago. Not terribly good for color compared with my Epson, but it's very quick for making B&W copies and has a legal size bed which often is quite handy--e.g. scanning LP covers. Works great with my HP Laserjet 4P that is also over 10 years old. At the time, both units were about $1000. Things are sure cheaper today.
wwaag -
Way to go wwaag ! Usb to scsi adapter great suggestion and I'm looking into those, thanks. I didn't know there was such a thing, now I do. I got to find a cheap one or one to borrow just incase they don't work. Does this 'termination' plug still have to be attached, and what happens if one isn't ?
Originally Posted by cyflyer
We have two scanners and three printers, then we bought a AIO (All-in-one). Since then, all the printer and scanner are retired as bulky paper weight.
Yo can also use a Firewire to SCSI adapter. I have a Ratoc FR1SX FireWire(IEEE1394) to Ultra SCSI Converter and this puppy drives properlly my really old Artec AT3 SCSI scanner (very good for OCR matters).
I also use it to connect a DLT tape to my laptop.
What type of sound card do you have in your computer?
By johns0 in forum PollsReplies: 19Last Post: 14th Mar 2012, 17:03 -
Quantum DLT8000 & SCSI card Available
By sdsumike619 in forum Authoring (Blu-ray)Replies: 1Last Post: 6th Dec 2011, 16:07 -
URGENT! Firewire card for computer
By dakota413 in forum Capturing and VCRReplies: 9Last Post: 10th Aug 2011, 17:22 -
computer will not boot with old modem card removed??
By cal_tony in forum ComputerReplies: 15Last Post: 16th Mar 2010, 10:58 -
Recommend AGP 4x capture card for P4 2.4GHz computer please??
By w@ntonsoup in forum Capturing and VCRReplies: 16Last Post: 9th Oct 2007, 11:05
