I bought an external usb 2 LG (GSA-2164D) 16x DVD burner which came with NEro 6. Now when burning films to DVD it takes a bloody age. Usually between 1.5-2 hours for a 4,7gb single layer DVD+ disc. IS this normal or is there a setting I am missing which is making this thing take so long. I can't recall it taking so long even on my old 4x DVD+ drive and I have heard times of 10-15mins quoted elsewhere. Is it because of USB 2.0 which I got instead of firewire. Help, I'm so fed up with archiving it's doing my head in.
Are you sure it's running in USB 2.0 mode? That sounds more like USB 1.1 times.
And you are using Nero. Are you sure Nero isn't doing it's typical re-encoding and that's what's taking all the time?
And no, that's not normal.
16X DVD media should take about 6 minutes to burn, though 12X is sometimes a better choice, depending on the media used. If you are just burning the VIDEO_TS folder, use ImgBurn instead. It won't re-encode.
And welcome to our forums.
HO can I assertain what the computer USB mode is. Ie how can I find and change the usb to use 2.0 if it is defaulting to the old mode? I aint computer savvy
To see if you have USB 2.0 in your system: 'Control Panel>System>Hardware>Device Manager>Universal Serial Bus controllers' and look for a 'Standard Enhanced PCI to USB Host Controller. The important word here is 'Enhanced'. If you see that, you should have a USB 2.0 setup. Any of the rear USB jacks on the computer should work as USB 2.0 then. Occasionally the front USB jacks are USB 1.1 on a few systems.
If you don't see the 'Enhanced', then you either don't have the proper upgrade, or you need to add a USB 2.0 PCI card.
The SP1 update should have USB 2.0 capability built in. -
A DVD burner can never go slower than 1x, which equates to ~1hr., so if it's going longer than that, it must be doing something else in addition (like RE-ENCODING
). Use an authoring program that's smart enough to leave good streams alone when you tell it to...
Best long lasting Blu-ray disk???
By hasselblad in forum DVD & Blu-ray WritersReplies: 36Last Post: 9th Jun 2014, 22:01 -
How long does it take to Burn a Blu-ray?
By DGenerateKane in forum Authoring (Blu-ray)Replies: 1Last Post: 6th Sep 2009, 06:01 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 03:12 -
Burning as Divx- burn time-why so long-alternates?
By Rik62 in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2008, 18:19 -
Burn in Disk Utility
By andredanton in forum MacReplies: 4Last Post: 12th Feb 2008, 13:41
