I tried burning some video files, and the total size for all the files was around 4.45 GB, and I wanted to burn them all on a regular 4.7 GB DVD-R or DVD+R, but it says that I don't have enough room. Is there anyway I can fit all 4.45 GB on the discs?
Closed Thread
Results 1 to 15 of 15
4.7GB = 4.38GB.
Long story short - media companies / salesmen and women claim that 1GB = 1000 MB, 1MB = 1000KB and 1KB = 1000B. Of course we all know that 1GB = 1024 MB, 1MB = 1024KB and 1KB = 1024B.
So, 4.7GB = 4,700,000,000B according to the companies.
But really, 4,700,000,000 / 1024 / 1024 /1024 = 4.377GB
So no, you won't be able to fit all 4.45GB in its current form. You will need to either lower the bitrate of your audio and / or lower the bitrate of your video and / or edit one or more clips, and across all files you should be able to squeeze out the extra 70-100MB or so that you need.If in doubt, Google it.
The often quoted "4.7GB" size of a single layer DVD is a misrepresentation, because they are counting 1GB = 1000MB = 1 000 000 KB = 1 000 000 000 Bytes, while just about ALL computer counting (INCLUDING filesize and disc capacity limitations) is done:
1GB = 1024MB = 1 048 576 KB = 1 073 741 824 Bytes.
So what you REALLY have available is 4.37GB. So 4.45 will always be too big for single layer.
You must either burn dual layer discs, split the program in 2, or recompress to a lower bitrate (and thus, filesize).
edit: jimmalenko beat me to it again!
I really wish that people that don't know the answer would just not post. The flipping label tells how many BYTES the disc will hold. It "claims" that the disc will hold 4.7 Billion (or giga) BYTES, and guess what THEY DO.
The problem is that dumb people think that 1GB (in computer terms)=1000000000 Bytes, which it doesn't, so they THINK that the disc manufacturer is lying or that there is some weird difference in conversion. There isn't, the packaging is 100% correct, you're just too stupid to understand.
Originally Posted by Matt D
I'd been wanting to burn a 720 MB ISO for a while, but only had 80 minute CDRs labelled "700 MB". Then in a media shop looking for some larger ones I found some other 80 minute CDRs labelled "730 MB". Then it clicked. A real duh moment. I'd been cursing the idiots who made the ISO oversized till then.
Originally Posted by kiches
Anyway, to make it fit you can use ReJig to recompress the MPEG video a few percent. There is a small loss of quality. I'm pretty sure DVDShrink does this too, but I haven't used that.
Think of seamen referring to a distance as "8 miles". Now is that 8 statute miles (12.8km) or is that 8 nautical miles (14.7km) ?If in doubt, Google it.
Uh, you "comprehensively answered" it WRONG. "Media Companies" and "salesman / women" DON'T "claim that 1GB = 1000 MB". They do however "claim" that those discs will hold 47000000000 BYTES of data, and they DO. A byte is a byte is a byte, and THAT'S how the size of the disc is measured.
So, there's no weird conversion needed, there's no lying or misleading going on. It's the GOOFS who think that they are not getting the full capacity that are the problem.
http://www.pcguide.com/intro/fun/bindec.htm
Jesus Christ, what a bunch of RETARDS. The packaging is OBVIOUSLY telling how many BYTES the discs are (that's what the B in GB MEANS MORON) using the decimal GB, and you'd know that if you have half a brain.
Take your full dvd video_ts folder that "only" holds 4.37GB and left click it and look at the BYTES. I'll bet you any amount of money that the number is really close to 4.7 billion bytes (GB) WHICH IS WHAT THE F-ING PACKAGE SAYS. The fact that the digital GB is different doesn't matter ONE F-ING BIT because a BYTE is still an f-ing byte.
You are in breach of the forum rules and are being issued with a formal warning. Reread our rules.
/ Moderator Baldrick"Rarely is the question asked: Is our children learning?"
George W Bush - Moron
Anyone worth their salt knows that GB is a standard unit of Base 2, and is undefined for Base 10. Therefore by using the GB unit they are implying that the measurement is also Base 2, which it is not. If it said 4,700,000,000 Bytes on the packaging then I would agree with you.
Originally Posted by Matt DIf in doubt, Google it.
@Kitches
Use dvdshrink, the quality loss with be minimal (doubt you would notice it)
@Matt D
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 01:53 -
Make AVCHD fit to 1 dvd5?
By alc112 in forum Authoring (Blu-ray)Replies: 16Last Post: 11th Jul 2010, 03:05 -
DVD file too large to burn to disc..how can I make it fit?
By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 08:14 -
how to make the a4 background fit the whole paper ?
By freestyler9 in forum ComputerReplies: 3Last Post: 27th Feb 2010, 16:44 -
How to make these Avi files fit to Burn
By jkraze in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 20:24
