hi there to every one i really dont know if this is the correct thread to post this but i am new and i do have a problem .
i have downloaded a movie 5 parts . all play well in vlc and klm media classic player but for some reason they wont convert to any format .neither it would burn to cd as a vcd. as for some other reason by right clicking on the file and going in to its propertise it shows 'file type : file' i cant understand it doesnt even show its format and yes they r fully downloaded.
plz help
Results 1 to 26 of 26
excitezone, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
jimmalenko where i downloaded it from they didnt say anything about any format. i use Xilisoft video converter .i have tried everything but these files are an unknown format
What you downloaded was probably rar'd or 7z'd to break file size into distributable chunks. If you don't have it, dowload 7zip and select all files and right click to extract. This should give you one file to verify the format.
heres some more info
type: Not known
Video: MPEG1 Video 352x240 (107:80) 29.97fps 1150Kbps [Video]
Audio: MPEG Audio 44100Hz stereo 224Kbps [Audio]
Subtitle: DVD Subpicture [Subtitle] -
Originally Posted by excitezone
You can download and install AVICodec then simply right click on the file in Windows Explorer - choose AVICodec and see what they are.
If .avi then they can easily be spliced back together using VirtualDub and it's append AVI command. There are guides available for doing that.
Good luck. -
You can tell by the video and audio specs you posted above that you have have NTSC VCD-compliant MPEG files. You should be able to rename to filename.mpg and most programs should open them then, as they are probably .DAT files at the moment.
... Or you may have "Hide extensions for known filetypes" ticked ...
If you're using Windows ME, Windows 2000, or Windows XP
On your desktop, open My Computer.
Select the Tools menu, & then select Folder Options ....
In the Folder Options windows, click on the View tab.
Uncheck the box next to Hide file extensions for known file types (Note that I have checked and unchecked other boxes that may not apply to you. If you would like to make your View tab resemble mine below, go right ahead; however, it is not necessary if all that you wish to do is reveal the "dot 3" file extension.).
Click OK to close the Folder Options window.
Close the My Computer window.If in doubt, Google it. -
I guess I type pretty slow. I missed 2 or 3 posts while typing.
You guys are too fast for me---> -
jimmalenko
thanks dude alot u have goten me really far ok now i renamed tem to 01.mpg and it works plus now even the propertise show file type:mpg file .. but still it wont convert nor burn -
I am not familiar with the software you are trying to use to convert, which means one of two things:
1. A new program has come out that I am not aware of that does a reasonable job
2. A new whizz-bang all-in-crap-one software has come out, that I have not had reason to touch with a 10ft pole
I favour option 2
Have you tried to convert with any other softwares ?
What do you want to convert to ?
You should be able to author straight to VCD using either Nero or VCDEasy.If in doubt, Google it. -
thats the problem jimmalenko it doesnt convert in nero direct it shows failed to encode i am preasently using Xilisoft Video Converter .i mostly use Xilisoft as i have been using it for quite some time now never had any probs with it tho..but if u know of anything that could get me to convert these files to mpeg1 i would be grateful many thanks on your help so far
Are you trying to make a VCD, or what ?If in doubt, Google it. -
General #0
Complete name : H:\MY VIDS\005
Format : MPEG-1
Family : MPEG-1
File size : 50.1 MiB
PlayTime : 596h 31mn
Video #0
Codec : MPEG-1 Video
Codec settings : CustomMatrix
Bit rate : 1150 Kbps
Bit rate mode : CBR
Width : 352
Height : 240
Aspect ratio : 16/9
Frame rate : 29.97 fps
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.454
Delay : 268069378
Audio #0
Codec : MPEG-1 Audio layer 2
Bit rate : 224 Kbps
Bit rate mode : CBR
Channel(s) : 2 channels
Sampling rate : 44 KHz
Resolution : 16
Delay : 268022376
Video0 delay : -47002 -
Originally Posted by jimmalenko
One thing that could possibly be happening is that the files were DAT files. Normally renaming works with them, but you may need to try renaming them back to DAT files, then using VCDGear to do a DAT -> MPG extraction. Failing that, can you open the files in virtualdub ?
jimmalenko U ROCK MAN U HAVE SOLVED MY PROBLEM U EXPLAINED TO ME AS NO ONE ELSE I POSTED ON MANY BOARDS FOR THIS HELP BUT EITHER PEOPLE SAID INCOMPLETE DOWNLOAD OR SOME THING OR THE OTHER MY PROBLEM IS SOLVED DUDE MANY MANY THANKS .NOW A DAYS IN OTHER BOARDS THERES A WAY TO REPP FOLKS TO GIVE THEM REPUTATION BUT I DONT SEE A WAY TO REPP OVER HERE SO I CANT REPP U BRO BUT I AM REALLY THANK FUL MAN VCDGear HAS DONE THE JOB FOR ME WITH YOUR HELP jimmalenko
.DO U KNOW MAN I HAVE BEEN STUCK WITH THIS VID ON MY HD FOR 5 MONTHS FINALLY ON CD SOON THANKS TO U -
I guess it just goes to prove that this is the best board out there !
BTW you can thank me by donating to the site, so that we can help others like you
PS. Just a friendly netiquette warning:
Typing in ALL CAPS indicates shouting - and there's no need to shout.If in doubt, Google it. -
Originally Posted by Scorpion King
Well I guess they stretch the height to fit full screen then crop the sides.
Convert .exe video tutorials(built by Screencam) to video format
By cyforex in forum Video ConversionReplies: 3Last Post: 1st Apr 2012, 16:11 -
help, i can't manage to convert this video format : .TS
By Michael REMY in forum Newbie / General discussionsReplies: 6Last Post: 22nd Aug 2010, 11:07 -
MD video file format - how can I convert it?
By bahjan in forum Video ConversionReplies: 6Last Post: 20th Apr 2010, 08:05 -
How to convert video format of a video made on iMovie on a mac?
By squeejiboo in forum MacReplies: 1Last Post: 30th Jun 2008, 06:47 -
Video won't convert to Widescreen
By RogMcDodge in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2007, 14:46
