I'm playing around with converting DVD's to Xvid and find the image quality is amazing, but turning a 90 minute movie into AVI takes about 5 1/2 hours. Is there a program out there that'll do this in a much shorter time. Also, is the Xvid codec better than the Divx codec? Just seems that way to me. Thanks.
Results 1 to 9 of 9
5.5 hours seems awfully long. I'd expect half that, judging by your system specs. However, it depends to quite some degree on what tools you use, and how you use them.
/Mats -
Around 5 hours on a p4 2.7GHz laptop (I'm guessing that is what you have) seems normal (to me) for good quality DivX/Xvid. On a Pentium M, Turon or Solo spec'd laptop, it should be somewhat less.
There are possibly some tweaks that will improve your times, but we need more info from you about your software/settings.. -
am a little new to convert from DVD to Xvid. I rented a DVD from my library to rip and convert it to Xvid like my pal had done. hes away on holiday for a month (A MONTH? yeah..... i know) but i want to learn myself to convert DVD to Xvid and rip subtitles from it. Its the friends Series 3. I wonder what tools i would need it read on this post here
I would need AutoGK and a DVD ripping program i have DVD Decrypter and subrip to rip subtitles from the DVD is that correct? Now i never used AutoGK, so I don't know what the settings are and etc.... so do i just the the settings as it is??
RaidersProfoundly deaf.
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 19:24 -
xvid to dvd converting help
By victoriabears in forum Video ConversionReplies: 12Last Post: 15th Nov 2010, 20:00 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 15:10 -
Converting from DVD to XVID
By morphjk in forum DVD RippingReplies: 11Last Post: 23rd Jul 2007, 16:33 -
Converting DVD to Xvid with a watermark?
By RushMaster in forum DVD RippingReplies: 1Last Post: 18th Jun 2007, 00:31
