I'm currently using DVD santa to author my .mkv, .avi, ect to the dvd files and was wondering if there was any faster programs out there. I know that DVD Santa is the best (from what i've been able to find) for the .MKV format but is there something better? Right now it takes about 2-4x the length of the movie to recode it. I do understand that there will be a delay of course because recoding is a intense process, just hoping for a bit more speed.
Thanks.
Actually, DVD Santa is crap, IMNSHO. ConvertXtoDVD claims to be able to handle MKV files now. On my system a 90 minute avi takes around 50 minutes to encode at highest quality.
FWIW, none of these solutions will give the best output. They all aim for speed and ease of use - quality is much lower down the list of priorities. The best solution takes a lot longer. On my system, doing it the manual way (for me that is FitCD, avisynth, ProCoder, DVD Lab Pro) takes around 4 - 6 hours (depending on the length of the movie) from start to finish. The quality is generally 30 - 50% better than what ConvertXtoDVD can do.Read my blog here.
Interesting - how do you measure that?Originally Posted by guns1ingerIn the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
Don't confuse authoring with format conversion. I'll move this to a more fitting forum.
/Mats -
So it's measured in subjective percents? (just teasing).
How you perceived the difference in quality was, however, seriously meant.In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
Hi there,
Also please take into consideration, that if you select DVD5 as your output, ConvertXtoDVD will reduce the bitrate (If needed) to make it fit on your DVD5.
If you wish (If possible) a better quality output, select DVD9 so it has double the space to output.
And VSO Software uses FFMpeg in ConvertXtoDVD !
My 2 cents...
Suggestions of Professional DVD Authoring Software
By kei_siuip in forum Authoring (DVD)Replies: 25Last Post: 16th Jul 2013, 21:36 -
Suggestions for DVD authoring with multiple audio streams
By farmkid in forum Authoring (DVD)Replies: 11Last Post: 19th Sep 2011, 18:23 -
DVD authoring programs - suggestions?
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 22nd Apr 2010, 14:53 -
I'm looking for a good DVD Authoring program. Need suggestions please.
By LegendaryGamer in forum Authoring (DVD)Replies: 5Last Post: 5th Mar 2010, 21:35 -
Authoring Region Free DVD's
By Deter in forum Authoring (DVD)Replies: 7Last Post: 9th Jan 2010, 17:45
