I am trying to convert a 6.03GB VOB file to a size that will fit on a DVD by using the dvd4 Tool in the Tools tab. The file is a single VOB file, created from MacTheRipper. The conversion fails with the folloing log... any ideas?
Code:Now scanning ac3 audio, please wait.. Frame length is 1792 Finished. No bad frames encountered Now recompressing video stream, please wait.. M2VRequantiser by Makira. Using 1.487655 as factor. INFO: [mplex] mplex version 1.9.0 (2.2.7 $Date: 2006/02/01 22:23:01 $) INFO: [mplex] File /Users/barskey/Movies/CRZ0NNW7/VIDEO_TS/CRZ0NNW7.VOB.m2v looks like an MPEG Video stream. INFO: [mplex] File /Users/barskey/Movies/CRZ0NNW7/VIDEO_TS/CRZ0NNW7.VOB.ac3 looks like an AC3 Audio stream. INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options! INFO: [mplex] Found 1 audio streams and 1 video streams INFO: [mplex] Selecting dvdauthor DVD output profile INFO: [mplex] Multiplexing video program stream! INFO: [mplex] Scanning for header info: Video stream e0 (/Users/barskey/Movies/CRZ0NNW7/VIDEO_TS/CRZ0NNW7.VOB.m2v) INFO: [mplex] VIDEO STREAM: e0 INFO: [mplex] Frame width : 720 INFO: [mplex] Frame height : 480 INFO: [mplex] Aspect ratio : 16:9 display INFO: [mplex] Picture rate : 29.970 frames/sec INFO: [mplex] Bit rate : 9800000 bits/sec INFO: [mplex] Vbv buffer size : 229376 bytes INFO: [mplex] CSPF : 0 INFO: [mplex] Scanning for header info: AC3 Audio stream 00 (/Users/barskey/Movies/CRZ0NNW7/VIDEO_TS/CRZ0NNW7.VOB.ac3) INFO: [mplex] AC3 frame size = 1792 INFO: [mplex] AC3 AUDIO STREAM: INFO: [mplex] Bit rate : 57344 bytes/sec (448 kbit/sec) INFO: [mplex] Frequency : 48000 Hz INFO: [mplex] SYSTEMS/PROGRAM stream: INFO: [mplex] rough-guess multiplexed stream data rate : 10470296 INFO: [mplex] target data-rate specified : 10080000 ++ WARN: [mplex] Target data rate lower than computed requirement! ++ WARN: [mplex] N.b. a 20% or so discrepancy in variable bit-rate ++ WARN: [mplex] streams is common and harmless provided no time-outs will occur INFO: [mplex] Run-in delay = 9009 Video delay = 9009 Audio delay = 12012 INFO: [mplex] New sequence commences... INFO: [mplex] Video e0: buf= 0 frame=000000 sector=00000000 INFO: [mplex] Audio bd: buf= 0 frame=000000 sector=00000000 INFO: [mplex] Scanned to end AU 90315 INFO: [mplex] Sequence end marker! Running out... INFO: [mplex] Run out PTS limit to AU 90316 339035697 SCR=338986861 INFO: [mplex] Video e0: buf= 192873 frame=090315 sector=01135126 INFO: [mplex] Audio bd: buf= 15677 frame=117708 sector=00104630 **ERROR: [mplex] Need to split output but there appears to be no %d in the filename pattern /Users/barskey/Movies/CRZ0NNW7/VIDEO_TS/CRZ0NNW7.VOB.4.mpg
I've found the source of the "%d" error, in my case at least. It's the DVD distributor's splash screen (or whatever it's called) that precedes the movie proper. Once removed, DVD4 worked without a failure.
Here's a workaround: rip the movie using 0SEx, with Fmt set to "Prog. Streams" and Seg set to "Cell." You'll end up with a folder filled with many VOB files. Play the first few in VLC to find the distributor's screens (mine was only the first one). These are the files you will delete or ignore. Join the remaining files with the unix "cat" command using extract's method. Use DVD4 on the resulting VOB file.
Problem merging video clips and suggestion on best tool?
By nerys in forum EditingReplies: 1Last Post: 18th May 2011, 00:41 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
Can I copy a DVD9 to a DVD4??
By hzgg2 in forum DVD RippingReplies: 1Last Post: 10th Oct 2008, 14:56 -
Tool to fix audio pitch problem from DVD?
By haymes in forum EditingReplies: 0Last Post: 29th Nov 2007, 17:15 -
Which tool ?
By NICEBUD in forum Authoring (DVD)Replies: 7Last Post: 17th Jul 2007, 14:06
