I have been trying to burn dvd file. I am using a lite-on external. Using dvd+r. It just will not play on my coby dvd player with no codes. I am placing a log record from nero. If anybody has any suggestion I would appreciate your help.![]()
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
NT-SPTI used
Nero Version: 7.5.7.0
Internal Version: 7, 5, 7, 0
(Nero Express)
Recorder: <LITE-ON DVDRW SOHW-1673S>Version: JS0D - HA 1 TA 4 - 7.5.7.0
Adapter driver: <USB 2.0> HA 1
Drive buffer : 2048kB
Bus Type : set to ATAPI (3) -> ATAPI, detected: ?
CD-ROM: <HL-DT-ST DVD-ROM GDR8161B>Version: 0045 - HA 1 TA 0 - 7.5.7.0
Adapter driver: <IDE> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV1204H nvatabus Port 0 ID 0 DMA: Off
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8161B nvatabus Port 0 ID 2 DMA: Off
CdRomPeripheral : SAMSUNG CD-R/RW SW-248F nvatabus Port 0 ID 3 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVD-ROM GDR8161B D: CDRom0
SAMSUNG CD-R/RW SW-248F E: CDRom1
LITE-ON DVDRW SOHW-1673S F: CDRom4
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 66060288 (0) Byte
BUFE : 0
Physical memory : 447MB (458096kB)
Free physical memory: 33MB (34216kB)
Memory in use : 92 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
9.11.2006
ISO compilation
7:58:18 PM #1 Text 0 File SCSIPassThrough.cpp, Line 583
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
7:58:19 PM #2 Text 0 File Isodoc.cpp, Line 6508
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
7:58:19 PM #3 ISO9660GEN -11 File Geniso.cpp, Line 3313
First writeable address = 0 (0x00000000)
7:58:19 PM #4 Text 0 File Burncd.cpp, Line 3435
Turn on Disc-At-Once, using DVD media
7:58:19 PM #5 Text 0 File DlgWaitCD.cpp, Line 301
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 764431 (169:52.31, 1493MB)
7:58:19 PM #6 Text 0 File DlgWaitCD.cpp, Line 313
Write in overburning mode: NO (enabled: CD)
7:58:19 PM #7 Text 0 File DlgWaitCD.cpp, Line 2863
Recorder: LITE-ON DVDRW SOHW-1673S, Media type: DVD+R
Disc Manufacturer ID: RICOHJPN, Media Type ID: R03, Product revision number: 4
Disc Application Code: 0, Extended Information Indicators: 7
7:58:19 PM #8 Text 0 File DlgWaitCD.cpp, Line 485
>>> Protocol of DlgWaitCD activities: <<<
7:58:19 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 820
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 764432 (764432) = #764432/169:52.32
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 764432 blocks [Main]
7:58:19 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 1033
Prepare recorder [LITE-ON DVDRW SOHW-1673S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1565556736, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 764432 | 0 | 0x00
0 | 1 | 1 | 0x41 | 764432 | 0 | 0x00
764432 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
7:58:19 PM #11 Text 0 File SCSIPassThrough.cpp, Line 41
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
7:58:19 PM #12 Phase 24 File dlgbrnst.cpp, Line 1746
Caching of files started
7:58:20 PM #13 Text 0 File Burncd.cpp, Line 4262
Cache writing successful.
7:58:20 PM #14 Phase 25 File dlgbrnst.cpp, Line 1746
Caching of files completed
7:58:20 PM #15 Phase 36 File dlgbrnst.cpp, Line 1746
Burn process started at 16x (22,160 KB/s)
7:58:20 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2730
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
7:58:20 PM #17 Text 0 File Cdrdrv.cpp, Line 9234
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Media type ID: R03
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 52 49 43 4F 48 - 4A 50 4E 52 30 33 04 38 ...RICOHJPNR03.8
23 54 37 13 00 44 73 00 - 84 6D 15 15 0B 0B 08 08 #T7..Ds..m......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
7:58:20 PM #18 Text 0 File DVDR.cpp, Line 6747
Drive: LITE-ON DVDRW SOHW-1673S
Book Type request [LO], rev 3: DVD-ROM
Changing the Book Type was finished successfully, return code 0
7:58:20 PM #19 CDR -1207 File DVDR.cpp, Line 6143
Book Type automatically set to: DVD-ROM
7:58:20 PM #20 Text 0 File DVDPlusRW.cpp, Line 662
Start write address at LBA 0
DVD high compatibility mode: No
8:02:22 PM #21 Text 0 File WriterStatus.cpp, Line 112
<LITE-ON DVDRW SOHW-1673S> start writing Lead-Out at LBA 764432 (BAA10h), length 0 blocks
8:02:35 PM #22 Text 0 File DVDR.cpp, Line 6747
Book Type request [LO], rev 3: DVD+R
8:02:35 PM #23 Phase 37 File dlgbrnst.cpp, Line 1746
Burn process completed successfully at 16x (22,160 KB/s)
8:02:40 PM #24 Text 0 File Cdrdrv.cpp, Line 10459
DriveLocker: UnLockVolume completed
8:02:40 PM #25 Text 0 File SCSIPassThrough.cpp, Line 583
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 11/30/2005 12:00:00 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Does it play on your PC ?
Does it play on any other DVD player ?
If you open it on your PC, what files and folders do you see ?
Does your Copy player recognise +R format discs ?
Was the disc you burned PAL or NTSC ?
What media (brand and ID) did you burn to ?
What messages, if any, does the player give when it refuses to play the disc ?
Some things to note :
1. Nero isn't the best for burning DVD video. I would recommend strongly that you use imgburn 2. It's free and damn good.
2. Not all players are compatible with all media. You may have to find a media brand suitable for your player.
3. In the US it is not uncommon to find that PAL format material will not play either at all, or at least correctly, in many players.Read my blog here.
The dvd does play on pc but not on any of the dvd players. One of my dvd players is compatible with dvd +r/-r/rw. When I open file on pc I see four folders. One - windows movie, two- quickfinder file, three- ms info document and the last one is a sub file.
I do have it to NTSC. The dvd player just has a wrong disc message. -
It's not a DVD, that would be the first problem. You have created just a data disc with a movie file on it.
If you want it to play in standard DVD players, you need to convert it to a DVD structure. This is a multi-stage process that starts with Encoding, followed by Authoring, and finishing with Burning.
A simple solution is ConvertXtoDVD. There are better ways, but they are generally more complex and require multiple steps and programs. There is an older, free version called DivxtoDVD which might suit you to start with. You could also try NeroVision, which I personally don't like, but many use anyway.Read my blog here.
Problem: Final Cut Pro, taking a 24p HD Blu-Ray and making a DVD with Toast
By apollo1980 in forum Authoring (DVD)Replies: 1Last Post: 22nd Apr 2010, 10:03 -
Making a DVD compilation - MPEG2 to DVD problem
By Dingler in forum Newbie / General discussionsReplies: 11Last Post: 1st May 2009, 14:40 -
have a problem making multi-episode dvds??
By roboroach in forum SubtitleReplies: 0Last Post: 18th Dec 2008, 17:39 -
Problem making backup of The Dark Knight Region 2 DVD
By soneman in forum DVD RippingReplies: 4Last Post: 14th Dec 2008, 16:48 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03
