I have a Dell flat panel monitor which I am planning to send to the Philippines. Written on the back is 100~240 volt. How can I be sure that it is safe to plug it into 220 volt? Should I trust them or there is a simple way to test it?
The CPU (Dell also) has a toggle switch to adjust to either 115 and 230 volts. This one I can check by putting it on 230 volt. If it does not start up, then maybe it really is 230 volt.
A sure test would be to try it. 2X step-up transformers should be easy enough to acquire. Then wire the low side with a male AC plug and the high side with a female AC socket. Just make sure the transformer is rated for the voltage, wattage, and frequency (60Hz) involved. But keep in mind that if it really cannot take 230VAC, you could easily destroy it. -
Thanks.
Perhaps I will tell them to first use a voltage converter(step-down) and if it is not available, then they can switch the CPU to 230VAC, pray and plug it and the monitor to their outlet. Electricity is one of the many things that I do not understand so I am bit paranoid. Perhaps I would not worry if it is the other way around. If the equipment will come from there to here.
having a dual monitor issue....
By lordhutt in forum ComputerReplies: 6Last Post: 17th Aug 2010, 19:21 -
Dual Monitor problem
By A Traveller in forum LinuxReplies: 18Last Post: 28th Oct 2009, 14:11 -
Suggestions where to get Dual monitor wallapaper?
By Denvers Dawgs in forum Off topicReplies: 7Last Post: 16th Mar 2008, 22:29 -
How to create a dual monitor setup?
By Denvers Dawgs in forum ComputerReplies: 20Last Post: 1st Mar 2008, 21:00 -
Dual LCD monitor probs....
By kenmo in forum ComputerReplies: 2Last Post: 13th Jun 2007, 14:17
