I have some video that has the mpeg 4 quicktime logo but will not play in quicktime at all. However with vlc they play great. In the information window (in VLC), i checked the coding of a video i have that play fine in front row and quicktime, against one of the ones that won't. They both say avc1 for audio and mp4a for video. Also visual hub will not convert the files to mp4, something about missing a audio codec or something. Any ideass would be great
When i do a "get info" on files that work in front row and those that dont they both say the codecs are H.264 and AAC. I'm pulling my hair out. Oh and the good one says the channel count is 2 the bad one doesnt say anything about channels.
Eric
Is it possible to post the vid somewhere I might DL it and try it? Perhaps I can then suggest another way to skin the cat.
They are pretty large files so i dont really know how i would go about posting them
Maybe try running the file through DivX Doctor (with the "make stand-alone movie" checkbox enabled) and see if the resulting "mov" file may be played with QT Player properly.
You can use YouSendIt.com, SendSpace.com or MegaUpload.com for hosting temporary files.Originally Posted by ekrispin
Play a video at 8x with sound?
By blud in forum Newbie / General discussionsReplies: 23Last Post: 5th May 2012, 21:40 -
Cell Phone Shut Down During Video and Video Won't Play
By Chief4Life in forum Newbie / General discussionsReplies: 13Last Post: 17th May 2011, 21:26 -
How to play a video?
By max.1911 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2011, 03:55 -
Play HD from PC via s-video
By craigarta in forum Software PlayingReplies: 3Last Post: 16th May 2010, 00:15 -
MT2S files play video in MPC but no sound+Ultra Cyberdvd wont display video
By btvs2000 in forum Software PlayingReplies: 7Last Post: 22nd Sep 2008, 15:44
