  1. I have a real media file that is at a constant 30 fps. I've cut up the rm file so that I could convert it using Tinra. Some of the converted avi's are in perfect sync, but some tend to become out of sync at the end. I tried using Virtual Dub to resync it, but haven't had any luck. Any ideas?
  2. Tinra uses RealPlayer to decode the .rm clips in real-time. If your PC drops frames while decoding, it's possible to get an AVI that is out of sync and can't be fixed.
    I've never had a problem using VirtualDub to sync an avi created with Tinra. If you have an avi that Tinra created and you can't sync it with Virtualdub, would you mind e-mailing it to me? (the source .rm, not the avi )
