hi
simple quaestion...i have a dvd on my hdd video ts audio ts and i extract the ac3 the sub and... now i want to add a subtitle...if you look around the subs are always for divx...so how i can find the right one and if the frame rate is not the same or ithe sub is in 2 cd how i get it to work on a dvd?please help me i can t find a solution please please
A subtitle is a subtitle, doesn't matter if it's for Divx or not. Just search for the language you require and as long as the framerate is the same it should work. If the timings are slightly out then you will need to edit them, it's a long job though
Try Subtitle Workshop to edit.
He's a liar and a murderer, and I say that with all due respect.
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 00:48 -
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 13:31 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
how to make a DVD subtitle as a default playing subtitle
By yozloy in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2008, 10:51
