if something is recorded in hd but the resolution is only 512 by 288 if i uncompress the avi would that give me its possible original resolution, bottom line is can compressing a file reduce the resolution
Results 1 to 10 of 10
If it is recorded in HD, the resolution should be higher than 512x288. That sounds like a SD broadcast on an HD channel.
I also don't know of any hardware that "records" HD in avi format.
What is the source and type of the files in question and what are you trying to do with them?Google is your Friend -
Typical broadcast HD is either 1280x720 progressive or 1920x1080 interlace.
http://www.kiva.org/about -
"Compressing" video has to do with lowering the bitrate (for storage or transmission efficiencies), it has NOTHING to do with raising or lowering its pixel resolution (or color bitdepth or framerate). Often, because a certain type of compression ONLY works with certain bitdepths, or with certain choices of resolution, people equate the compression as the active force in the change of resolution, but that's actually done in "pre-processing", which may or may not be integral to the encoder.Originally Posted by adriac25
So the short answer is:
No, you WON'T get back whatever the original resolution was, whether you uncompress it or not (of course, we all know it has to get uncompressed for display anyway).
Resizing won't get it back its original resolution either--it'll be an upsized, blurrier ESTIMATE.
Scott -
Well you see i downloaded the video for "backup purposes" the quality is amazing and looks hd and it is said to be shot in hd only but the problem is the resolution, also if uncompressing cannot do it then couldnt a program like transition hd or tmpgenc 4.0 solve the problem by increasing the resolution, i hear those programs can do it without losing any picture quality
Take a 1280x720 HD still frame. Reduce the frame size to 1x1 pixel. Now enlarge that small image back up to 1280x720. What will it look like? Will it look as good as the 1280x720 original?
Or let's try it this way: I have two numbers. I'm going use my advanced number resolution reduction process to reduce them to one number. The result is 97. What were the original two numbers? -
What he said was (to paraphrase),"You cannot re-encode to increase resolution and get better quality." It's lost, gone, never to be recovered.
"Art is making something out of nothing and selling it." - Frank Zappa -
And from your description, you are downloading files that were recorded in HD and then reduced in resolution. This is done to make them compatible and follow the "standard" for video releases. Unless you are using an HTPC, you wouldn't be able to play them back in HD resolution anyway.
He has a low resolution video that may once have been high resolution.
If you need it for backup purposes then back up from your original.Originally Posted by jagabo
In search for an uncompressed video capture card
By xyzxyz in forum Capturing and VCRReplies: 39Last Post: 24th Mar 2013, 08:45 -
How do I save uncompressed video fast
By crankyslap in forum Newbie / General discussionsReplies: 0Last Post: 29th Dec 2010, 18:14 -
BD / DVD Digital Video Quality as compared to Uncompressed RAW video.
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 09:11 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
How to convert uncompressed video to lossless HD
By Freeloader in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2010, 12:59
