Hello,
I have some VCD and other MPEG-1 files that were 16:9 source from DVD and were encoded to 4:3 (not letterboxed). I was wondering if there are any programs that will fix the flag in the MPEG Header so I don't have to re-encode these files to another format to fix the Aspect Ratio. Thanks
VCD/mpg1 doesn't have AR flag like DVD/SVCD/mpg2 do, IIRC. It's always 4:3
/Mats -
Thanks Mats,
So there is no way to change these to 4:3 Letterboxed either?? -
Not that I know of (without reencoding).
I used to to that kind of encodes when I did VCD just because they'd look right when I set my TV to 16:9.
/Mats -
You'll have to re-encode it in smth. (e.g. TMPGEncXpress) that has resizing function with ability to add borders. Resize it to 352x176 and add 2x32pix borders top/bottom before encoding to VCD NTSC.
Is playback of mpeg-ps streams possible on a pc?
By craig198 in forum AudioReplies: 2Last Post: 26th Apr 2011, 11:12 -
MPEG TS Streams missing LFE channel ?
By s1lenc0r in forum AudioReplies: 3Last Post: 17th Apr 2010, 09:20 -
Mux raw subtitle streams in a existing mpeg file.
By etvideob in forum LinuxReplies: 0Last Post: 14th Aug 2009, 02:22 -
New experimental TS cutting software for MPEG-2 and H.264 Transport Streams
By Nukster in forum EditingReplies: 2Last Post: 14th May 2009, 09:16 -
Swap audio streams in MPeg-2
By billyygli in forum AudioReplies: 1Last Post: 10th Apr 2009, 09:31
