Seems yesterday purchasing the software took 4 tries to get my Credit card to work, and 4 tries to get it installed but finally it is working well.
So my question is..
Is there any way to set a default location for the final TS file, the mpeg goes into the source folder, which I do not mind, bu the TS files I would like it set to be in the same folder with each conversion ect. So that is a simple way to find/delete ect when it is done.
Btw I have set the folders in preferences but they do not seem to actually go there after the settings are saved.
Thanks in advance
Purplemagpie
Mmm. It should work that way. Can you attach your log file where this happens?(logs are kept in the "logs" folder under where you installed SVCD2DVD)Btw I have set the folders in preferences but they do not seem to actually go there after the settings are saved.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Here is the one I believe I am working on, currently. In the file it shows where I wish to have the items sent but does not seem to go there. Another person who uses this at work here also has the same issue, it seems to default to where the program is loaded, and I found the files actually in the menu folder.
Thanks for the response!
requestedlog.txt -
ok. That log doesn't actually finish. Do you have a complete one?
Here is another log, largest one there, I believe this is complete as it was one that went over the night.
secondattempt.log -
This looks like a Batch remux run. Ideally what i need to see is a complete "Create DVD" run. That is the only time VIDEO_TS folders are created and so will be the only time your issue arises.
Assign default audio and default subpicture streams for movie only backups.
By mattstan in forum DVD RippingReplies: 12Last Post: 11th Sep 2012, 05:59 -
VlC became default audio player, some how, but I can't default 2 foobar?
By Denvers Dawgs in forum ComputerReplies: 1Last Post: 17th Sep 2011, 18:38 -
A way to share files by default in Windows when connecting new disks?
By Talayero in forum ComputerReplies: 5Last Post: 6th Jun 2011, 09:09 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 09:56 -
Changing Vegas' Default Media Library Location
By ShBm in forum EditingReplies: 0Last Post: 9th Jun 2007, 14:22
