The camcorder is a Sony DVD203 The computer is an HP with WinXP, AMD 64, 512mb, 200gb (if this matters)
The software that came with the camera does not detect the camera when I plug it in. I called Sony and they did not help me at all. There is a program that came with my computer called Intervideo WINDVD. It detects and plays the video from the camera, but does not let me do anything else with it. Windows Media Player also plays the video. The computer also came with Windows Movie Maker, but it says "a video capture device was not detected" I have downloaded several free video editing programs from the internet, but have not had luck with them either. Basically all I want to do is to be able to save my videos onto the computer so that I can upload them to the internet. This has been very frustrating. I have been messing with it for a few weeks. Does anybody have any advice?
Thanks Mike
Results 1 to 17 of 17
windvd is strictly a media file PLAYER. period. if your camera has a firewire port and your computer does also, with the proper firewire cable you can capture the output with the free program WinDV allow for 13Gbs per tape of hard drive space. that will get the dv avi onto the computer, what you want to do with it from there will require encoding software.
There is a WinDVD Creator program which sometimes ships as a freebie (I know a lot of our laptops have it if they ship with a DVD Burner). It is a simple tool, not unlike Window Movie Maker, but able to produce a DVD at the end of the process.
Read my blog here.
The only ports on my camera are USB, remote, and AV. My computer has a WINDVD Creator, and WINDVD Player. All I want to do is be able to take the video from my camera and get it onto the internet using my computer. How do I go about this? Here is a link to my camera
http://www.shopcartusa.com/Product/dcrdvd203/Electronics~TV_Video~Camcorders/Sony_Hand.../?ic_campID=98 -
I dont know what folders and files are on the DVD. I just recorded something real quick for practice, finalized it and put it in the computer.
Do you know how to use Windows at all ?
Open Windows Explorer by double-clicking on the My Computer icon on the desktop. You should see your DVD drive as one of the drives being displayed. Double-click on it and it should should you what is on the disc in that drive.Read my blog here.
Did your camera come with the Picture Package software?
XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card -
Did you read page 89 of the manual?
"Connecting you camcorder to your computer - Introduction"
"Install the USB Driver before connecting the camcorder to your computer."XP
600GB
2G
Originally Posted by guns1inger
Everything that you have told me has been obvious. Of coarse I have read the manual. I guess im not a big enough dork to be on this forum, kinda figured that when I registered...a bunch of dorks trying to sound cool and try to make people with problems feel like idiots. I tried all of the things that you guys have said the first day I got the computer. Everytime I try something it does not work. If you guys are so smart you should know what problems I encounter when I try using certain methods/software. Go ahead and ban me from this gay site since I can tell im not going to get the help I need. Better off to just figure it out on my own.
You are in breach of the forum rules and are being issued with a formal warning. If you ask for help, at least try to be patient and show a little courtesy. While it can be frustrating, no one here has a crystal ball, so any 'obvious' answers or questions are down to you for not providing enough info.
/ Moderator offline -
Please answer the questions below - sorry if some sound obvious....
Originally Posted by 347Stroker
I assume you are connecting via the USB port. Is it USB 2.0? I think it needs to be. Also, it will depend on the Service Pack version of Windows XP. Which do you have?
Since you can play the DVDs on your PC, you don't need to transfer from the camcorder in the traditional sense. All the files you need are on the DVD. If you look at a folder listing of the DVD, you should see a bunch of folders some of which contain files with .VOB suffix (at least, that would be my expectation). These .VOB files are the MPEG2 video files. You need software to allow you to edit/convert these .VOB files.
What software came bundled with the camcorder?John Miller -
If everything is so obvious, will you please tell us what guns1inger asked you - what do you see when you put the DVD in the PC? What is the folder and file structure?
As for trying everything that we suggested, if you really did this, you did not describe it very well. You say that Windows does not recognize the camera when you plug it in, but you do not say if you installed the drivers first.
It seems to me that if a Windows program (in your case WinDVD) is playing the disc while the disc is in the camera, then Windows is recognizing the camera, at least as a UMS drive or external DVD drive. If this is the case, and you cannot browse the DVD when it is in your PC drive, you should be able to navigate to the camera in your Explorer directory.
Fact is, I want to help you, but not for you, but for the next person who comes along and needs help. As your name says, you're a stroker.XP
600GB
2G
go somewhere else if you're going to have that attitude. You have refused to do the simple steps asked of you (like tell us what files/folders are on the dvd when you put it in your computer) and my crystal ball is out of order right now.
If you think editing video's is dorky then why are you here? Coming to a videohelp site asking for help, then saying it's dorky because you either cannot grasp simple concepts or are too lazy to do so is counterproductive.
Trouble Capturing to Sony Vegas 8
By croonprince in forum Capturing and VCRReplies: 6Last Post: 26th Jul 2011, 22:38 -
Are you a handyman?
By johns0 in forum PollsReplies: 16Last Post: 7th Sep 2010, 11:33 -
Trouble with SONY DVD+R disc and SONY player/recorder
By Winston99 in forum Newbie / General discussionsReplies: 3Last Post: 29th Mar 2010, 22:54 -
Sony Handyman on a Mac
By jcpacp in forum Capturing and VCRReplies: 1Last Post: 24th Oct 2008, 12:06 -
Streaming video from Sony Handyman?
By jcpacp in forum Video Streaming DownloadingReplies: 5Last Post: 20th Oct 2008, 13:49
