Hi I did a clean install Of WinXP and installing and testing everything I reinstalled but Im getting some blips along the way. The lastest was Pinnacle Studio not burning to DVD-RW but I think I have that solved so tried again but asked for blank dvd when it normally says disc not empty do want to erase the contents which I would reply yes but it does not do that any more so I used nero to erased disc but when I go to burn disc again it asks for blank disc?
Finally The question do I have to format this disc to reuse it [by the way Im talking DVD-RW] and how do you do it plus in nero it also asks for blank disc when I put in the dvd which was erased
Thanks for any help
I think Pinnacle is treating the disc as DVD-R not as DVD-RW so will unistall a particular software to see if this will solve my problem
Sounds like one or more of your programs are interfering with one another. I would uninstall Nero and Pinnacle Studio (and any other burning programs you have installed). Then reinstall and test them one at a time. That way you will be able to tell which program is hosing everything up.
EDIT: I vaguely remember reading about this issue before and it was related to Pinnacle Studio.Google is your Friend -
you have alcohol120% ?or other image burner softwares?
if yes than uninstall them and try -
image burner softwares interfere in our drive,so when you don't need them just uninstall them.
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
