Thread: .AVI vs .MOV re Milgila miniHD files
  1. #1
    Member
    Feb 2004
    USA
    Posts
    540
    Cheers
    My MigliaMiniHD is working very fine and I have had a lot of help here.
    the downloaded files are in a folder called .eyetv it contains several file types as mentinoned here before:
    .eyetvi .eyetvp .eyetvr and the key one: .mpg
    QTPro will not look into the eyetv folder to open the .mpg I have now the pro and mpeg-2 add on.
    Streamclip will if I ask for "all files" not just video files. If I open files this way and put them in "batch" with SC and use Sorensen3 the resulting file type is a .mov. a 800mb initially at 640 x480 that I make into a 320 x 240 and that ends being a .mov of about 700mb.
    I then use BatchExportUlility to take a lot of the above .mov and make the 3ivx 320's and those files end up being about 180MB which is fine for me
    the ElGato software that comes with it will allow me to open the .mpg and edit it and then save it with a Divix component that might expire (??) into a 320 x 240 .avi of about 180 mb.
    but it seems BUE won't open .avi files as far as I can tell to bbatch these smaller.
    any ideas why?
    the batch function helps me a lot as i then do a lot of these at night unassisted
    thanks
    rotuts
    MPro 2.66 3GB RAM 1.5TB HD's
    MigliaMiniHD
    QTPro, MPEG2 add on MPlayerX2
    MPEG Streamclip
    24 + 21" samsung flat panels
    G4dual 2GB
    AlchemyDVR card
    Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Posts
    4,219
    First, I know next to nothing about MigliaMiniHD or ElGato's EyeTV. But here as some thoughts anyway.
    Quote Originally Posted by rotuts
    I use BatchExportUlility to take a lot of the above .mov and make the 3ivx 320's and those files end up being about 180MB which is fine for me
    1/ If the 180MB is fine for you, then why try to make the 180 mb Divx even smaller?
    2/ Is your 'BatchExportUlility' the Livid Batch Export Utility v1.2? Because that one takes my AVIs happily.
    3/ The QuickTime DivX encoder from DivX.com expires (after 6 months) if you don't pay, but not the decoder (playback component). Not sure if that's the same as ElGato uses, or if encoding or decoding expiration is your worry.
    4/ I don't see why you mix 3ivx and DivX. Pick one and stick with it; they do basicly the same.
  1. LaCinema MiniHD Connect question - anyone using it?
    By Sv Bell in forum Newbie / General discussions
    Last Post: 31st May 2011, 07:32
  2. How do I convert MOV dv files to AVI?
    By SixStringSW in forum Mac
    Last Post: 17th Mar 2011, 00:21
  3. removing background noise in AVI files created from .MOV files
    By p_s_92 in forum Newbie / General discussions
    Last Post: 23rd Jun 2010, 08:26
  4. Replies: 5
    Last Post: 1st Jul 2008, 15:04
  5. Replies: 0
    Last Post: 9th Nov 2007, 05:57
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
